What grease to use on CV joint?
What type of grease (other than Swepco 101) should I use on the CV joints?
Unfortunately, I did not find a Swepco distributor here in Guatemala.
Mario
'76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger
'15 GT3
Old 07-21-2006, 04:02 PM
I've had good results with Liqui Moly LM47 with MOS2. I have not had good luck with Swepco on my wheel bearings. Lately I have switched to Valvoline SuperSyn. Just be sure to pack enough grease into the CV joint and boot (3 oz) so that the grease doesn't come out and make the joint run dry.
Old 07-21-2006, 04:43 PM
Mad scientist
Peter Bull's Avatar
Re: What grease to use on CV joint?
According to an engineer at GKN the best grease for CV-joints is a grease made by Neo Synthetic Oil called NEO HP CC #1. It is expensive and used by F1 and WRC teams.
Most known brand grease like GKN and Loebro will work just fine for every day use.
/Peter
'84 911 Carrera
'91 928 S4
You can't make a racehorse out of a bull, but you can make an awfully fast bull.
Old 07-22-2006, 12:57 AM
Peter, do you know where I can get NSO grease? I agree, the car probably came with el cheapo multipurpose grease. Just stay away from the fad-ish Redline synthetic. I think that stuff is way too thin and doesn't adequately protect the expensive and now hard to replace CV joints.
Old 07-22-2006, 06:14 PM
Mad scientist
Peter Bull's Avatar
You can find a dealer locator at Neo's site.
/Peter
'84 911 Carrera
'91 928 S4
Old 07-23-2006, 02:26 AM
randywebb's Avatar
Originally posted by rusnak
... I have not had good luck with Swepco on my wheel bearings. ...
- What happened with the Swepco?
Old 07-24-2006, 12:37 PM
Randy, I noticed that the Swepco thinned more and I got more wear than when I was using the Liqui Molly. LM is still my favorite grease, but It's hard to find and does not come in cartridges. Redline grease is awful.
Old 07-24-2006, 12:46 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
You can order the LM from our host in either sizes.
That is where I purchased it.
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 07-24-2006, 01:45 PM
Thanks for all the inputs.
Also, do you use any type of sealant on the CV joint on top of, or instead of, the gasket? i changed the CV joint/boots very recently and grease keeps coming out. I did re-torque the CV bolts a couple of times after the installation, but I am still having the problem.
Mario
'15 GT3
Old 07-24-2006, 01:52 PM
Matt,
The LM is only available now in the small tube. But that's the good stuff for sure.
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=911M&section=SUSaxl&page=1&bookmark=1&part_number=3510-M19
Old 07-24-2006, 03:22 PM
Trying to add a picture
Old 07-24-2006, 03:36 PM
