rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Here you go. BTW. Got the muffler and exchangers together last night. Muffler went on beautifully. Since it was 1 AM. I thought I'd wait till today (after work) to put the oil back in and listen to the music?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 08-01-2006, 08:33 AM
Ok so if you clip the existing wire clean with the Original O2 with a new one being 6 inches will it work then??
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 08-01-2006, 09:44 AM
rs6er's Avatar
I'm not sure what you're saying. I think you are asking if I cut the wire off the original sensor right at the sensor and got a new sensor with 6 inches of wire to replace the original, I could then splice the new sensor's wire to what's left of the old one and it would reach. Actually, I'd need 8-9". The Bosch part mentioned above comes with only about 2 1/2" of wire though. There is a $30 Bosch sensor with a longer wire and a female spade connector at the end of the wire that I could use if I attach a male spade connector to my existing wire (or cut the connector off and use a butt connector or solder), but I hate to pay $30 for a few inches of wire, since my factory sensor is pretty new.
John
Old 08-01-2006, 10:04 AM
yeah thats what I was thinking. I think that you could probably find that wire locally maybe even radio shack but you would have 2 butt splices which is not good for resistance
Ben
89 944,85.5 944
914-6werkshop.com
Old 08-01-2006, 10:15 AM
rs6er's Avatar
Does it have to be a Bosch sensor? Also, did the 74 exchangers have a sensor?
John
Old 08-01-2006, 10:50 AM
no and no I would guess you would be fine with what ever you can find
Ben
89 944,85.5 944
914-6werkshop.com
Old 08-01-2006, 12:05 PM
