Addicted to Racing
Turbo O2 sensor position
Hi,
I have a race 911 turbo. I have a zork tube for an exhaust. The question I have is where should the o2 sensor be mounted. Before or after the turbo. And if one or the other, how far from the turbo or outlet pipes. Thanks Ed |
Smart quod bastardus
You should try to keep it after the collector for at least 3 exhaust pipes, but before the turbo so that it is real hot. The O2 sensor needs to be above 600 degrees to function properly.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
How much power increase did yousee by adding just the zork tube versus the muffler?
Thanks, Fred
Addicted to Racing
This motor was built ground up for road racing, so it never had anything but the zork.
Thanks Ed
Check out the parts for sale: http://www.demonspeedmotorsports.com PCA National & NASA Instructor, NASA GTS & PCA GT Class Racer. See my list of current cars in my garage. |
after the turbo 6-12 inches.
Williamknightperformance.com Perfectpower.com |
