engine bay rust
Hi all, a newbie here...
Take a look at this engine bay picture. I see what appears to me to be rust on the back wall of the engine bay. Is this a cause for concern? What if the rest of the car turns up rust free? Is the rust in the engine bay a deal breaker? Thanks for any advice you can give me.
Old 08-14-2006, 01:17 PM
Jays72T's Avatar
Glue from sound pad that is missing. Don't worry.
Jay
'08 E350 Wagon
'74 914 gone
'72 T gone
Old 08-14-2006, 01:19 PM
defcon65's Avatar
What you think is rust may just be the adhesive residue from a missing engine pad - mine looks the same way. You can check this by trying to clean it off with a solvent like lacquer thinner. They sell replacement pads on this site or you can fab one yourself using a variety of materials- there are a lot of threads on this issue, just search 'engine pad' on the 911 tech forum.
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 08-14-2006, 01:23 PM
Friend of Warren
I agree just that crappy glue.
Kurt V
Old 08-14-2006, 01:24 PM
Ok thanks guys... so my newbie follow-up questions would be...
1. what function does the engine pad serve?
2. do I need it or do I need to be concerned that this car doesn't have it?
I appreciate the help.
Old 08-14-2006, 01:28 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
The main purpose of the engine pad is to lower the sound level in the car's interior that is generated by the engine running.
I would replace it at the first engine drop, but not until then. You can only replace it while the engine is out.
-Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 08-14-2006, 01:32 PM
defcon65's Avatar
It makes the engine slightly less noisy, but only below 5000 rpm. Let it sing!
Joe
85 Carrera
Old 08-14-2006, 01:34 PM
Slumlord
Porsche_monkey's Avatar
With no disrespect intended if you can't answer those questions you should not be considering buying a 911 off eBay. Do a search on PPI's and eBay purchases. Or just tell me to mind my own business.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 08-14-2006, 04:43 PM
