AC condensor fan
I have an 86 Carrera that I have put all new hoses and components for the AC system in. I have good cold air again. The fan in the front that blows on the front condensor is not getting any power. I have tried all different settings. I see in Bentley that there is a relay for this circut. Can you tell me where it is located and how can I test its operation? I have checked the fuses. Thanks
Relay on the earlier 911 such as my 82sc was located in the smuggler box.
You can spend beaucoup bucks and buy a Porsche genuine part that is made in China or go to rat shack and buy their automtive relay which is a direct fit for under 5 bucks. Last edited by ruf-porsche; 06-21-2006 at 06:36 PM.. |
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
The relay in the smugglers box for the A/C....which used to have an internal diode prior to '88...was updated in '88 to include an "external" jumpered connection and an installed fuse.
Alan Caldwell who writes on such matters in Panorama.... also described this change and it made no sense to him, (nor to me ....nor to any other person who understands electrical circuitry). I went ahead and installed this goofy updated relay anyway.... can anyone here explain the function of the external fuse ?? - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
They over engineer everything. |
Senior Member
The fuse is to keep the car from burning up when the fan siezes, which has happened hundreds of times in the field.
If your car does not have a fuse in the inline power wiring to the condenser fan, it needs one.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Joeaksa
You're confusing the front condenser fuse addition ( 7.5A ATO style added by the factory in '88)...with the external fuse that piggy-backs on the relay mounted in the smugglers box. Neither I nor even Alan Caldwell from Pano...who writes about such things....can explain the logic for this piggy-back arrangement..... - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 08-17-2006 at 09:49 AM.. |
+ lurking - contributing
Stunistu, must ask how hard was the barrier hose install, DIY?
87 930 96 BMW M3 Coupe 89 951 08 Astra H Peugeot moped |
The bottom line is that it's a very DIY-able job.
1984 Targa |
I had this same issue on my '89 and it turned out to be a bad relay....it should be up front, in the trunk fuse box.
Marc Morrison 1964 356C coupe '89 911 coupe 2008 Honda Accord 2008 Ford Ranger |
