Gear ratio vs speed calculation help
Assuming a 915 with a 7/31 ring and pinion and a 26/26 5th gear running 335/30/18 rear tires, what would the wheel speed be at 7000 rpms?
Thanks in advance.
John H 2001 996 GT3 Cup 1969 911T 2015 Cayman GTS |
'94 VW Jetta '85 VW Scirocco '81 911 SC coupe Euro '67 VW Bug |
Used Up User
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
I prefer to go back to first princpals and do the calc myself. You can get a more accurate result by inputting the actual dynamic loaded radius rather than the static unloaded radius that most of the calculators use.
The dynamic loaded diameter of a 335/30x18 tire is 25.1 - 25.4" depending on the tire the formula is MPH = (RPM*DLR*0.002975)/(TR*DR) RPM - revolutions per minute DLR - dynamic loaded diameter TR - transmission ratio DR - differential ratio For your example, using an average of 25.25" for DLR MPH = ~119mph
Thread Tools | |
Rate This Thread | |
