911 driver
Source for Color Coded Wires and Water Proof Connectors
I have decided to move the fuse box inside the car, under the dashboard, and need to replace/extend some wires. My local auto parts shops carry only single color wires but I would like to keep the stock color coding to avoid confusion. Does anyone know a place, preferably a website, where I can order what I need?
When I upgraded to flat style fuses a couple years ago I used single color wires with plastic identification tags to replace corroded wires. This works ok, but this time I want to retain the stock color coding. If I can´t find a perfect match for the factory colors anything better than the 4 different single colors I can get at my local shops would help. I know that one way of getting a lot of different colored wires is to buy a harness from an old car at a wrecking yard. I have done this before. But after finding corrosion all the way through the wires going to the right headlight I want to use new parts. And I don't want to spend a fortune buying a new factory wire harness which I would have to extend/modify anyway. I am also looking for some high quality water proof connectors for this project. The Deutsch connectors from http://www.deutschconnector.com/ look good and they have nice flange mount receptacles available. The other brand to consider seems to be Weatherpak. Other suggestions?
Ove '77 911S targa |
Irrationally exuberant
Eagle Day and Rhode Island Wire carry the wire you are looking for.
The have web sites but I'm too lazy to look them up right now. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Ove,
+1 more for R.I. Wire. I have done business with them. They are top-notch. Chris
1986 Carrera Coupe 1987 Dodge W250 2000 Volvo V70 2007 Land Rover LR3 |
Eagle Day sells the connectors and porsche wire the color you need by the foot.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
On new replacement Porsche wiring harnesses, you'll often see that rather than using 'factory' striped wire what was used was the base color wire with a strip painted on. Often very crudely.
When, as often happens, I can't get the wire color combination required, or I need it 'now', I use vinyl model paint: an acrylic for plastics and vinyl made by Vallejo (www.acrylicosvallejo.com). I use the 'Game Color' line, buy from: http://www.fantization.com Cheap, easy to apply and when left to dry for an hour or two - does not scratch off at all and is water and solvent proof. It's easy enough to apply that I stripe the whole wire rather than the ends: you never know when you might have to break into a harness or bundle. Jim
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R ________________________ 2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI |
As to the waterproof connectors:
the expense to buy the Packard Weatherpack series terminals, shrouds, towers and crimping tool is totally well worth it. You'll be surprised at the ease of use and the 'everywhere' applications it will take you. Available here: http://www.waytekwire.com/index.htm Weatherpack here: http://order.waytekwire.com/CGI-BIN/LANSAWEB?WEBEVENT+L0B2FB56E0B790900FC3E042+M37+ENG and the next page of that series products Jim
911 driver
Thanks for the replies
Jim, Using vinyl paint is a great suggestion! I will stop by my local toy store on my way home. I know they sell various types of paint for plastic models. Does anyone have experience with Deutsch connectors?
Buy a Used One
Why dont you buy some used electrical supplies from Yagi Electricals. It will save you a lot of money!
Eagle Day
I can't find Eagle Day's website any longer, are they closed? Who else sells Euro automotive wiring in the US of A
Ubi bene ibi patria
They might be outta bizness......EagleDay.com This domain is for sale: $13,295
Anybody have an alternate supplier in mind? Cheers JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke "As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras |
What are you looking for ?
Search for Timmy2 in this forum, he fabricates harnesses and Porsche specific connectors. Have you tried https://4rcustomswire.com/ https://www.ynzyesterdaysparts.com[/url] http://www.riwire.com/ http://www.cycleterminal.com/index.html http://www.britishwiring.com/default.asp https://www.autosparks.co.uk/ Last edited by donporfi; 04-23-2025 at 01:15 AM.. |
