Member 911 Anonymous
Heck why not, more knowledge is better for all of us.
Just curious how you will connect the +12v connections, what brand did you buy? Was it the guys from NY? I almost bought it but wanted a brand others here tried and tested for measure.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
without factory electric locks as a stock item in 1977 I installed Porsche electric door solenoids and the arm connecting to the door lock. I then went aftermarket for the relay pack and hooked it up to my Viper alarm beeper. I also installed up-graded window regulators, etc.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
So which +12v fuses did you use?
i use an 8 circuit breaker panel mounted next to battery. others will tap into battery directly or tap into trunk fuse panel.
Hmm. very interesting. Do you have pic of your set up yet?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 11-27-2007 at 03:45 PM.. |
timeless beauty
Hope that helps, Bob |
![]() Glad you replied, So just to verify, when you said #11 relay, you mean #8 hazard light indicator relay in panel section 1, right?
The kit is from this guy in Seattle that has a bunch of power door lock kits on ebay. The reason I chose his is because he lists the actuators as "heavy duty". In my research on ebay I found actuators ranging in force from ~2.5kg - ~5.0kg. He didn't list the exact force these actuators apply, but I'm keeping my fingers crossed they'll be enough. I'll start a thread once I get the kit and have some time to do the install. Wish me luck! Jon
- Everything's easier once you get started. - '95 993 C2 '73 911 Targa '88 BMW M3 '84 Mercedes 190e 2.3 16v |
timeless beauty
Success!
Thank you Magic930 & Rcaradimos for your detailed installation. Here is my experience and verification of some issues: The Black Widow BW854, does come with some poor installation instructions for our P-Cars but tech support is great. *Basic Features - 8 wires in total: 3 to Ground Connection= Black, Violet & Violet/Black 2 to Power Source = Red & Yellow 2 to Power Lock Control = Blue & Green 1 to Parking Lights = White via Diodes Valet Button is needed for Programing and the LED is helpfull to see if programing was accepted by the module. I placed my LED where the interior cab temperature sensor would have been. *Remote Transmitter Layout - is definitely not marked properly, the Unlock is Button 2 and not the Trunk Button (actually #3) as stated in the manual. This is very important for proper programming of the module. *Valet Mode - To turn off or "override" valet mode you must hold the switch for over 5 (5-10 per tech support at BW) seconds and not 3 seconds as stated in the manual. This is the only way to turn off the LED Light when in Valet Mode. *Diodes - Radio Shack was out of stock and did not know when they will get some so I went to my local ham radio/electronics store and purchased some 3 amp diodes. The tech stated it is more than I will ever need. He said 1 amp would do just fine but to be safe he sold me 2 3amp diodes. I used the blue crimp and folded to double the thickness of the white (parking light control) wire to fit properly. Remember the silver marked end toward the fuse terminals (Panel 2 Fuse 5 & 6). I used Rcaradimos method of connecting the module's red (constant +12v) wire to the Clock Fuse terminal ('85's Panel 1 Fuse 1) and the yellow (switched, ignition monitor) wire to the Windshield Washer terminal (Panel 1 Fuse 7 jumper, the terminal right between Fuse 7 & 8 as described by Rcaradimos). I also programmed the module not to auto lock when ignition is turned on. The range is pretty poor, 10 to 20 feet but it's OK as long as I do not have to put my key in the handle and stop scratching the paint is all I wanted anyways. Lights and LED works perfectly. Hope this helps someone. I had difficult time because the buttons were not marked properly but once figured out and spoke to tech line. It was a snap. I am very happy with the results. Thanks again fellas,
Update:
I got fed up with the low range of the Black Widows antenna so I did an experiment: My baby has two antennas one on the windshield and the power antenna that my radio is hooked up to. I was cleaning up the wires underneath the dash and saw the windshield antena just hanging there. I pulled it through the fire wall and spliced it to the Black Widow's antena. Not expecting much but SUCCESS! I now have a 30-40 yard radius range. Very Happy and no need to buy an external booster. So if you guys have both antenna's connect it and it will increase your range.
I put a Y connector in fender antenna wire to plug in the remote alarm pager transmitter. Big difference if antenna is up most of the way.
I have to disconnect the remote dook lock wire to the parking lights or put a fuse in line.
Whoa fuse? You used the diodes right? My electronic store stated 1 amp is good enough but 3 amps is a guarantee.over,
bell said crooks break the lens and short the bulb socket so the alarm brain crashes. So he said a fuse prevents that from happening.
So do you put the fuse on the LED line or the parking light circuit and if so what size (amp)? TIA
I haven't done it yet. I guess a 3 amp fuse should allow enough current to work the parking lights without blowing?
Oh I see,
When you do do it, could post a pic for us? TIA
I just finished the hook up today. I did the simple, simple hook up. No diodes, no horn, no flashing lights, nothing. Just lock and unlock. I also got it programmed so it doesn't lock when the ignition is turned on. The range for me as is is just fine for now. Thanks a lot for the thread Magic930 and everyone's comments. Couldn't have done it with out ya!
PS - I got the BW 854 from Amazon for ~42 shipped.
Bill 997.2 |
I recently installed mine, too. The harness has little tabs on the back – push the tab in and the wire slips right out. I removed all wires not necessary for simple lock and unlock. This makes a very clean install possible.
The system works great – I get about 40 foot range. Thanks for all the help – couldn’t have done this without it Paul ![]()
1985 911 Carrera Moss Green Metallic Steve Wong Chip, WEVO shifter & PSJ, Kuehl Air Conditioning |
EDIT: Made a few changes.
Bringing this one back from the dead. After buying the BW854 unit 3 years ago, I decided to install it this weekend, but I can't get it to work. I followed the posts above, but I must have done something wrong. I was looking for a simple install with no horn, dome lights, valet switch, remote LED or aux functions Can you guys check my wiring below? I replaced the remote batteries with new ones. The red LED light on the does work when a button is pressed. When I start the car, the door locks "lock". When I turn it off, the door locks "unlock". 3 to Ground Connection= Black, Violet & Violet with black tracer 2 to Power Source = Red to constant power & Yellow to switched power (per magic930's picture) 2 to Power Lock Control = Blue with black tracer to brown with green tracer & Green w/ black tracer to brown with blue tracer. 1 to Parking Lights = White via Diodes Any ideas? Last edited by A930Rocket; 03-15-2010 at 02:05 PM.. |
