Shift bushing
Does anyone have any tricks for getting the shift rod bushing (the one in the tunnel behind the shifter) into the bracket that it fits in. The part has a 3mm lip and there doesn't seem to be any graceful way of getting the 36mm diameter lip into the 30mm hole in the bracket. (This is on a '69 911)
Also, our host sold me part number 914-424-224-00 for the bushing while my PET shows 901-424-224-00. Is there any difference?
Old 09-14-2006, 07:36 PM
84toy's Avatar
Put it in some hot water for awhile to make it soft. It will go......
Paul S
"Those who say it cannot be done should not interrupt the people doing it"
Old 09-14-2006, 07:47 PM
Bird. It's the word...
Fishcop's Avatar
Warm it up, put a little grease around the rim and it'll pop right in...
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 09-14-2006, 08:26 PM
I used hot water, grease, and a bench vise. Went right in.
edit: I'm talking about the shift bushing! Jeeeze...................
Good luck,
Jim
Old 09-14-2006, 08:43 PM
Thanks guys, I managed to get it in - mangled it a bit in the process, but it went over the shaft and seems to work OK. The shifting is much tighter now. The old one had completely disintegrated so the shaft was just riding in the bracket with no bushing.
Old 09-14-2006, 09:04 PM
ruf-porsche's Avatar
Good luck,
Jim
We thought that was what you were talking about, why the edit?
LOL
Yeah the price, you brought a 914 parts which everyone on this board knows is cheaper than a 911 part.
LMAO
Old 09-15-2006, 05:42 AM
Here's how I did mine: How the heck do you "snap back in" the new shift rod bushing???
Warren & Ron, may you rest in Peace.
Old 09-15-2006, 10:23 AM
randywebb's Avatar
I thought the 914 part was round, not oval (?)
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 09-15-2006, 12:05 PM
NE Ohio 911's Avatar
After reading these posts, I decided to try my floor jack. I placed the l-bracket with the bushing on the jack and jacked it up to the bottom of my work bench which is bolted in to a concrete wall.
Bushing went right in, no busted knuclkes or mangled fingers. Hopefully this might help the next guy who does not have a press handy.
Doug
1984 Carrera Coupe
Old 02-03-2007, 06:20 PM
I hate freight charges
village idiot's Avatar
Send a message via Yahoo to village idiot
here's a diagram of how I did mine:
Tom
78 911SC SC to 73RS imposter SCWDP crew #50 and 51
1969 Camaro "The new project"
Old 02-03-2007, 10:30 PM
Won Won is offline
Won's Avatar
Originally posted by cegerer
Just cut it longitudinally with a hack saw! The material you remove will reduce the effective diameter slightly and it will slide right in. Might sound crazy, but it makes no difference whatsoever as to the functionality of the bushing. This isn't an engine rod bearing afterall, it's just the shift rod moving slowly back and forth through there. The cut is in the same direction as the rod travel so there really isn't any problems.
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 02-04-2007, 12:15 AM
randywebb's Avatar
I just cannot understand why Porsche didn't engineer some sort of ball bearing device, say with titanium balls to save weight. Or maybe starting with aluminum balls in the 1960s; then switching to magnesium later to save even more weight.... and finally switching back to Al again 'cuz the Mg wasn't strong enough....
Old 02-04-2007, 12:33 AM
