Shift bushing
Does anyone have any tricks for getting the shift rod bushing (the one in the tunnel behind the shifter) into the bracket that it fits in. The part has a 3mm lip and there doesn't seem to be any graceful way of getting the 36mm diameter lip into the 30mm hole in the bracket. (This is on a '69 911)
Also, our host sold me part number 914-424-224-00 for the bushing while my PET shows 901-424-224-00. Is there any difference? |
Put it in some hot water for awhile to make it soft. It will go......
Paul S "Those who say it cannot be done should not interrupt the people doing it" |
Bird. It's the word...
Warm it up, put a little grease around the rim and it'll pop right in...
John Forcier Current: 68L 2.0 Hotrod - build underway |
I used hot water, grease, and a bench vise. Went right in.
edit: I'm talking about the shift bushing! Jeeeze................... Good luck, Jim |
Thanks guys, I managed to get it in - mangled it a bit in the process, but it went over the shaft and seems to work OK. The shifting is much tighter now. The old one had completely disintegrated so the shaft was just riding in the bracket with no bushing.
LOL Quote:
LMAO Last edited by ruf-porsche; 09-15-2006 at 05:44 AM.. |
Here's how I did mine: How the heck do you "snap back in" the new shift rod bushing???
Warren & Ron, may you rest in Peace. |
I thought the 914 part was round, not oval (?)
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
After reading these posts, I decided to try my floor jack. I placed the l-bracket with the bushing on the jack and jacked it up to the bottom of my work bench which is bolted in to a concrete wall.
Bushing went right in, no busted knuclkes or mangled fingers. Hopefully this might help the next guy who does not have a press handy.
Doug 1984 Carrera Coupe |
I hate freight charges
here's a diagram of how I did mine:
Tom 78 911SC SC to 73RS imposter SCWDP crew #50 and 51 1969 Camaro "The new project"
83 911SC Targa Everything I say is my personal opinion, and has nothing to do with my team. |
I just cannot understand why Porsche didn't engineer some sort of ball bearing device, say with titanium balls to save weight. Or maybe starting with aluminum balls in the 1960s; then switching to magnesium later to save even more weight.... and finally switching back to Al again 'cuz the Mg wasn't strong enough....
