Old Member
Source for coil wire terminals for '84 Carrera
Update: Parts located, thanks.
I'm on a search for a coil wire terminal end to replace the one going to the dizzy.
Anyone know the nomenclature for the type of dizzy cap terminals used on the Carrera. I see the use of HEI type caps in the local parts house.
All I'm trying to do is replace the terminal end for the coil wire at the dizzy. The earlier coil wires are not the same size.
If I knew the proper terms for the terminals ends I should be able to buy the part at the local auto parts store on a Saturday.
I'd like to get the car back on the road tomorrow.
Clifton Brown
https://www.mancalamarketing.com
Old 09-15-2006, 07:29 PM
Jeff Alton's Avatar
Kingsborne should have them.
Cheers
www.turn3autosport.com
Old 09-15-2006, 07:49 PM
Old Member
Jeff
I think you got it exactly, thanks.
I found what looks like the correct terminal on their web site but I couldn't find any prices or how to order.
I'll give them a call on Monday.
Clifton Brown
Old 09-15-2006, 08:17 PM
Early_S_Man's Avatar
Porsche Crest
Pelican has them:
WIRE END-DISTRIBUTOR
- This is a special-order, non-returnable, part
(availability and shipping charges may vary).
OEM-92860255701 $20.48
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-16-2006, 01:27 AM
Old Member
Warren
Thanks, I should have checked a lot closer here first. Wayne is really adding to the list of available parts.
Clifton Brown
Old 09-16-2006, 08:05 AM
