Need somebody smart to do a calculation for me...
A company sent me a set of "air alert tire-valve caps" to try out and ideally write about. They're big and heavy, because they each contain a battery and a red LED that blinks if the tire pressure falls by four pounds. Very nice, but they weigh 0.35 ounce apiece, and I wouldn't dream of putting them on a fast car for fear of snapping the vale stem off at speed.
Can somebody good with numbers tell me what their effective weight would be at, say, 120 mph (a speed I'm sure a lot of us have done at one time or another...maybe more) on a 19-inch wheel? I want to be able to sound as though I know what I'm talking about when I tell the company that makes them that they're dangerous--which I think they are.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 10-04-2006, 12:11 PM
Super Moderator
cstreit's Avatar
I think you'd be in the 300 RPM range or so at 120mph... Ran a quick calculation I think it's like 600 G's or some ridiculous thing.. in other words, it weighs a LOT.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 10-04-2006, 12:19 PM
Super Moderator
cstreit's Avatar
((feetpersec * feetpersec) / 32.2) / radiusinfeet
feetpersec= 120mph*5280ft / 60min/60sec = 176
((176 * 176) / 32.2) / 1.58 = 608 G's...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 10-04-2006, 12:21 PM
Which means each valve cap effectively weighs 13.3 pounds at that speed, right?
Question for anybody, does that sound like weight that would do damage to a tire stem?
Stephan Wilkinson
Old 10-04-2006, 12:31 PM
Super Moderator
cstreit's Avatar
I don't think I'd put it on my rubber valve stems...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 10-04-2006, 12:32 PM
No I dont think that would be much of a problem. The tire monkeys have long levers to remove the stems. I think somewhere over 20 pounds and it never tears them no matter how old they are. Certainly this should be installed on shorty stems and not the long truck stems. Furthermore it would require a rebalance of the wheel. The steel stems would probably be best.
Old 10-04-2006, 12:37 PM
Super Moderator
cstreit's Avatar
Porsche saw fit to put stem supports on even basic rubber valve stems,... I won't even run them on the racecar ... Seems risky to me.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 10-04-2006, 12:41 PM
450knotOffice's Avatar
608 G's! Wow.
.35 ounces X 608 G = 212.8 ounces = about 13.3 pounds.
Mind you, the tip of the valve stem is significantly inboard of the outer radius of the tire so the G- forces wouldn't be quite as high as indicated above (this was based on the rolling radius of the tire), but it is still probably on the order of 1 pound. If the weight acting on the stem is not perfectly centered, centrifugal force will tend to force the valve stem out toward the edge of the tire, possibly leading to valve stem failure where it attaches to the rim. However, if it's one of the bolted-in types, that one pound or so of force probably would be insignificant.
This is just a guess on my part, btw.
(edited for a stupid math error)
Old 10-04-2006, 12:42 PM
I am an EE so I need practice. Somebody check
weight-mass
0.35 ounce = 0.021874997 lbs mass = 0.000679898 slugs
velocity
120 mi/hr = 176 ft/sec
radius
19 in dia = 9.5 rad in = 0.791666667 ft
F= m v^2 / r 26.60277889 pounds
Old 10-04-2006, 12:49 PM
Home of the Whopper
I did a real quick calc assuming an 18” rim with a 20” rolling diameter and came up a centrifugal force of about 22#’s each at 120mph.
It’s been awhile since I’ve done math so….
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 10-04-2006, 01:12 PM
We have 3 answers now, is there a prize?
A 19 inch wheel would have an 9.5 inch radius right?
Lets ask Wayne. Those MSMEs are supposed to know this crap.
The problem I would see with this is every time you went 120 mph the stem would flex over against the rim and then return again when you slowed down. How many times would a valve stem do this?
Old 10-04-2006, 01:26 PM
Home of the Whopper
I think we are close enough Rick. I used 18" as where the stem would actually be, for r = 9", and used 20" as the rolling diameter to determine W. I used a different formula though, I used:
F = m w^2 r
Old 10-04-2006, 01:47 PM
Interestingly, I queried the company about this, and they told me hundreds of thousands of these units have been sold in Germany and they have never had a valve-stem failure even in Autobahn use.
Stephan Wilkinson
Bill Verburg's Avatar
I came up w/ an answer close to CS's
here are my assumptions
235/35x19 Michelin PS2 26" OD 799rev/mi @120mph
valve cap is 9" from the axis orf rotation
answer
~653g
The cap will weigh ~653x it's static weight
Bill Verburg
Old 10-04-2006, 01:56 PM
skinnerd's Avatar
Just stick them on the racing steel valve stems, and you'll never need to worry about them....
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
I'm sure they'd be fine on racing steel valve stems, but how many ordinary consumers who will buy them at AutoZone even know what a racing steel valve stem is?
Stephan Wilkinson
Old 10-04-2006, 02:04 PM
Home of the Whopper
Ok, this bothered me so I used Bill's numbers in:
F = m w^2 r
and came up with 13.44 lbs, which is what CS said an hour ago. I like his method better.
Old 10-04-2006, 02:19 PM
If they were sold in Europe/Germany, don't they have to pass TUV testing?
Old 10-04-2006, 02:34 PM
TUV: yes, that's what I assumed, and I told the guy that if they were good enough for the TUV, they were good enough for me...
Stephan Wilkinson
Old 10-04-2006, 02:42 PM
Southern Class & Sass
Dixie's Avatar
You know, wheel weights are typically in 0.25 oz increments. The caps weigh 40% more than that!
I can see it now. Joe Average buys the caps at Pep-Zone and installs them. Now his Ford Taurus has a shimmy at 80. He takes it in to the shop. They take the wheel off the car, take the cap off, check the air pressure, and spin the wheel. Hmmm.... it's in balance.
Eventually it dawns on someone (probably Joe) that the caps are the problem. After all, replacing shocks, ball joints and tie-rods didn't work. After 30 minutes, the tire jockey decides to humor Joe and balance the wheel with the caps on. Viola! The problem is resolved.
On the ride home, Joe looses one of the caps...
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 10-04-2006, 05:10 PM
