WEVO Sway Bar Bracket Install mod
I wrecked my stock sway bar bracked with my lift arm so WEVO was the logical fix. Welding was done at a respected Porsche shop on the south shore of Long Island. I've spent a lot of time looking at the beauty of tuna tower welds and the shop's WEVO welding pleased me. It's not the simplest install but the job turned out with the sway bar bushing square with not offset to cause friction on the bar bushing.
The 1st pic is with the WEVO painted flat black The stock bushing brachet allowed to much play for the bushing to be mounted. I'm not sure if another bracket is available but the car has to be rolling very soon for a ride to Dragon's Tail so a stock bushing bracked tweak was called for. This is the stock unmodified bushing bracket. The actual depth of the stock bracket was too large so the bolt holes had to be die grinded. This allowed a baby sledge and a dull chisel to shape it around a socket similar to the bushing diameter. The bracked was slammed when mounted. raw pics
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Finished and ready
The long end of the bushing bracket was mounted to the rear. Excuse the never seize on the ss bolt and bushing grease. My bro has an '88 that has had the main bracket break more than once. He's buying the WEVO in advance. If his car goes in for a tune-up before the stock style breaks he'll do the WEVO to get the bs over with. Kinda like having a dash light fuse and relays for the headlights. I don't know if Pelican Parts has a modified bushing bracket. They did have the WEVO readily available.
Was it German Auto Repair, Amityville, NY?
Rudtners Racing in Freeport. The address changed from the card address to allow a trick chassis dyno install.
Yep those are one of those things that are on my list for the '73. Sure I could do all sorts of welding and bracing but those parts just look beefy!
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
Senior Member
Looks nice!
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Way to go, Ronnie!
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Yea looks like good stuff Ron.
Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
Ron, the bolt spacing was changed in 78. Earlier cars like yours have narrow bolt spacing. The wevo mount is built to the 78+ spacing.
Matching 78+ brackets with the correct spacing are readily available and not too expensive.
Chuck Moreland - elephantracing.com - vonnen.com |
Chuck is correct they are different for the 78-89 models. I think they are like $5.00 each or close to it, and they have a very durable black finish. That with new bushings may make a nice job into a perfect one. We all know how much you like perfection. Maybe this info will help. Pelican sells them. I bought a set 2-3 years ago for my 82` sc.
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_SUSshk_pg6.htm#item22 Kurt Williams
