the the is offline
Help diagnose '88 Carrera central locking problem
Did a search, found some info, but not spot on with my problem. There seem to be many ways for the system to fail!
Here's what it does:
Neither door will lock, either by the key in the handle (either side), or the push button in the center console.
You can hear it clicking in both doors when you use the key or the center console button, but it won't lock.
If you manually lock both doors from the inside (it's a cab so that's easy to do with the top down), and press the center console button or use the key, both doors will unlock as they should.
Normally, when you start the car, the doors lock themselves. That's not working, either.
Any thoughts?
Old 11-01-2006, 01:46 PM
the the is offline
Nobody?
Old 11-02-2006, 07:11 AM
Super_Dave_D's Avatar
Re: Help diagnose '88 Carrera central locking problem
[i]
[/B]
Really? My 88 doesnt do that????
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 11-02-2006, 07:18 AM
Toxic
derkpitt's Avatar
norm
That's not the norm, nor a factory option.
Do you have a after market keyless entry?
Bruce
88 Carrera Coupe, 12 Dodge Ram Hemi,
69 Barracuda Fastback, 68 Barracuda Convertible 5spd
The only substitute for cubic inches is cubic dollar$.
Old 11-02-2006, 07:24 AM
Throw it on the ground!
Auto lock on startup is not normal. My 87 does not do this.
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 11-02-2006, 07:26 AM
Wickd89's Avatar
I also have an '89 and the doors do not lock automatically in any way. I just have a choice of using the button in my lower center console or turning the knob on the door......
Thanks, Luis
Luis "once was - Wickd89"
Carrera 3.2 - "Faster, Stronger, Better"
-- 2008 Toyota Camry SE V6 (mine)
-- 2005 Toyota Sienna (hers)
-- 1989 911 Carrera Cabriolet -SOLD
Old 11-02-2006, 07:29 AM
makaio's Avatar
Sounds like you need to pop both door panels and see what's going on inside. I had similar problems and it was a broken ball cup for the linkage.
Old 11-02-2006, 08:33 AM
TroyGT's Avatar
Me too... I replaced my linkage with the later model carrera arms. No more worn out elbows in the future. My 86 doesn't have an autolocking system either. Sounds aftermarket.
1986 911 Coupe (Guards Red), Fabspeed Euro Pre-muffler,
Steve Wong Performance Chip
2001 Boxster 2.7L (Orient Red), bone stock
Old 11-02-2006, 11:48 AM
Czar of C.R.A.P.
dfink's Avatar
If it is like my 85' there is a relay that is stuffed up in right front firewall area behind the hinge mounted on the inside of the fender. Mine does the same thing except for locking when started. You can hear the relay click but lock the doors. The relay is very hard to see almost just have to feel for it. I have taken the connector off and on several times and that seems to help for a while. If you here the clicking then I would check the relay. Something to check anyhow.....
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 11-02-2006, 06:16 PM
