Help diagnose '88 Carrera central locking problem
Did a search, found some info, but not spot on with my problem. There seem to be many ways for the system to fail!
Here's what it does: Neither door will lock, either by the key in the handle (either side), or the push button in the center console. You can hear it clicking in both doors when you use the key or the center console button, but it won't lock. If you manually lock both doors from the inside (it's a cab so that's easy to do with the top down), and press the center console button or use the key, both doors will unlock as they should. Normally, when you start the car, the doors lock themselves. That's not working, either. Any thoughts? |
Nobody?
Re: Help diagnose '88 Carrera central locking problem
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) |
Toxic
norm
Do you have a after market keyless entry?
Bruce 88 Carrera Coupe, 12 Dodge Ram Hemi, 69 Barracuda Fastback, 68 Barracuda Convertible 5spd The only substitute for cubic inches is cubic dollar$. |
Throw it on the ground!
Auto lock on startup is not normal. My 87 does not do this.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
I also have an '89 and the doors do not lock automatically in any way. I just have a choice of using the button in my lower center console or turning the knob on the door......
Thanks, Luis ![]()
Luis "once was - Wickd89" Carrera 3.2 - "Faster, Stronger, Better" -- 2008 Toyota Camry SE V6 (mine) -- 2005 Toyota Sienna (hers) -- 1989 911 Carrera Cabriolet -SOLD |
Sounds like you need to pop both door panels and see what's going on inside. I had similar problems and it was a broken ball cup for the linkage.
Me too... I replaced my linkage with the later model carrera arms. No more worn out elbows in the future. My 86 doesn't have an autolocking system either. Sounds aftermarket.
1986 911 Coupe (Guards Red), Fabspeed Euro Pre-muffler, Steve Wong Performance Chip 2001 Boxster 2.7L (Orient Red), bone stock |
Czar of C.R.A.P.
If it is like my 85' there is a relay that is stuffed up in right front firewall area behind the hinge mounted on the inside of the fender. Mine does the same thing except for locking when started. You can hear the relay click but lock the doors. The relay is very hard to see almost just have to feel for it. I have taken the connector off and on several times and that seems to help for a while. If you here the clicking then I would check the relay. Something to check anyhow.....
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
Thread Tools | |
Rate This Thread | |
