The way Doug describes sounds like a good idea...any reason not to use this method? Are there any "gotchas" associated with this process? I always wondered if this was an option since it seems sort of intuitive.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 11-08-2006, 06:25 AM
Okay, for all those who are still subscribing to this thread,
since I started this post, I wanted to follow up with my adjustment results.
First off, I made a STUPID mistake the first time around. Instead of using the pulley marks when turning the engine 120 degrees, I turned the distributor rotor 120 degrees!
So I adjusted #1 correctly, turned the ROTOR 120 degrees, then adjusted #6 when in reality I was at #2! Then I rotated the ROTOR another 120 degrees, tried to adjust #2 when I should have been adjusting #3, and so forth.
This is why my car sounded like s**t after the first time.
After realizing my mistake, I did it the CORRECT way last weekend and used the PULLEY marks. Now the car purrs without clicking!
Lessons I learned:
1) use the Rotor ONLY to find TDC and Z1 and nothing else
2) Doug's GO NO-GO method worked like a charm and I do not forsee EVER learning or trying the CLASSIC method!
Brian
1989 Carrera 3.2 Silver Anniversary Edition
2007 BMW 750Li
2005 Honda Odyssey EX-L
http://forums.pelicanparts.com/porsche-911-technical-forum/285064-new-member-have-pics.html
Old 11-08-2006, 09:54 PM
