I suppose you could have corrosion in the CIS electrical connector aft of the FV valve, or somewhere else. It's a pretty short run from the relay to the flat black plug. Good luck!
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Check here for the FV signal waveform:
www.systemsc.com/waveforms.htm and then use a scope to verify that your Lambda unit is functioning properly.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
