Scott R's Avatar
Originally posted by Vin-barrett
Hiya Scott
When I checked the voltage at the FV connector I am taking the pulsed ground out of the loop - correct?
In other words I put one probe of my meter to one of the FV connector's terminal and the other grounded right to the engine. This is where I am getting the 8.5 volts.
Like you said about a temporary line going around wiring issues.
I'm thinking running a long wire from terminal 87b at the relay under the seat straight to the FV to see if I get anything greater than the 8.5. I'm not sure what the voltage should be either.
Yes correct measured from an engine ground. It is strange that your getting low voltage. I know from testing injectors in the past that you need pretty close to 12V to get them to crack.
I suppose you could have corrosion in the CIS electrical connector aft of the FV valve, or somewhere else. It's a pretty short run from the relay to the flat black plug.
Good luck!
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 11-28-2006, 07:48 PM
Lorenfb's Avatar
Check here for the FV signal waveform:
www.systemsc.com/waveforms.htm
and then use a scope to verify that your Lambda unit is functioning properly.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 11-29-2006, 06:36 AM
