paslantnose's Avatar
Timing Question
1980 3.0 SC
Just tinkering here and decided to check timing at 6K rpm.
We had initially set timing at 5* BTDC while at idle.
Checking it at 6K rpm, we found only 25* BTDC !
Mechanical advance is fully & smoothly functional.
Dizzy has dual vac canister with 2 vac hoses.
We reset timing to 35* at 6K rpm and it verified with 15* at idle.
Had to tweak the mixture slightly and took it out for a spin, it runs smoother and pulls stronger than ever now, even starts quicker.
Idle is very stable at 950-1000.
Previous exhaust popping on decel now almost non-existant
We're wondering if there is any problem with it being at 15* at idle or is everything OK???
Side notes: 02 sensore disconnected, decel valve disconnected.
No pinging even on regular fuel.
1980 911SC Slant Nose
Can you say MegaSquirt !
Old 11-23-2006, 08:18 AM
I've search many many threads that talk of how to time the motor but still no answer to my question of "will 15* BTDC at idle be OK or will it cause problems?
Surely someone here knows?
Old 11-23-2006, 02:39 PM
As long as you are convinced that 6000 RPM setting is indeed correct I wouldn,t worry about the idle setting as much. It does seem unusually adv. at idle though.When I had a 3.0 original 1980 motor it did,t like to idle well with alot of idle advance.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 11-23-2006, 08:30 PM
I poured back through many threads on this last night and come up with so many different settings that guys are using it's almost null to read it all.
30*, 32*, 35*, etc
I need to do a curve of the advance and chart it out then, compare to known chart i guess.
Anyone have the advance curve for a 1980 SC ???
Old 11-24-2006, 03:46 AM
Bill Verburg's Avatar
Spec for your car is
5&deg BTDC @ 900 &#177 50 w/ vacuum detached
RoW 23&deg - 29&deg @6000 w/ vacuum detached
US 19&deg - 25&deg @6000 w/ vacuum detached
Bill Verburg
Old 11-24-2006, 05:02 AM
Much appreciated Bill.
I guess I need to back her off a little then.
Dang, it runs so good @ 35*
Old 11-24-2006, 01:30 PM
T77911S's Avatar
as long as it does not DETONATE and u like the way it runs, all is fine.
too much advance=detonation. u will need to richen it up as u said u did. detonation is an engine killer
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-27-2006, 04:50 AM
