-   -   zuffenhaus C2 to '72 RSR project... (http://forums.pelicanparts.com/porsche-911-technical-forum/318580-zuffenhaus-c2-72-rsr-project.html)
drb930 08-30-2009 01:18 PM
Hi Keith,
Any chance you could help me out with sourcing for the ITB's?
I am building a 3.7 on a base 3.6 engine with a 993 RSR Intake Manifold for a 87 backdate to 72 and I think those ITB's that you have in the picture might work?
Also would you be interested in doing the same conversion on my 964 Oil Tank?
Thanks,
Dave
av winans 09-03-2009 05:27 AM
Dave, PM sent
911GT2 10-17-2009 03:58 PM
subscribed
eimkeith 01-06-2010 12:22 PM
OK, updates!
We took the shell with another client's 911 to e-coat - here are some action photos (Apple Iphone quality, of course):
The pair of 911s headed to chemical strip (these had previously been baked and phosphate coated prior to rust repair and modification)
http://forums.pelicanparts.com/uploa...1262807692.jpg
Lonely tubs in the recieving yard at the stripping facility. You can better understand visually the jigs that they must be mounted in for the e-coat process here.
http://forums.pelicanparts.com/uploa...1262807833.jpg
Chemically-stripped 911s being racked at the e-coat facility. It is extremely difficult to find a facility that can handle the length of the 911 unibody - if it were a full size domestic car, the body would actually be shorter in most cases, since everything from the firewall forward unbolts. Not so for the 13.5 ft Porsche unibody. Add to that 6' of width (flared cars) and 4' of height, and you need a shop with siginificant capacity in their e-coat tanks. Most of those facilities aren't available for 'jobber' work, being amost exclusively employed by the big 3...
http://forums.pelicanparts.com/uploa...1262807977.jpg
Headed into the first of many, many dip tanks...
http://forums.pelicanparts.com/uploa...1262808458.jpg
Kerplunk!
http://forums.pelicanparts.com/uploa...1262808562.jpg
More tank action...
http://forums.pelicanparts.com/uploa...1262808744.jpg
and so on, and so forth for several more dip tanks...
eimkeith 01-06-2010 12:23 PM
Coming out of the drying oven many tanks later
http://forums.pelicanparts.com/uploa...1262808880.jpg
http://forums.pelicanparts.com/uploa...1262808958.jpg
http://forums.pelicanparts.com/uploa...1262809023.jpg
Shiny black, e-coated new Porsche. - looks like a child's plastic model car before assembly, right?)
http://forums.pelicanparts.com/uploa...1262809078.jpg
And, Aaron just after attempting to explain to the nice policeman that the 45' trailer destroyed our transmission after the mountain climb the previous evening...
leaving us stranded in the median on the interstate. :rolleyes:
http://forums.pelicanparts.com/uploa...1262809283.jpg
eimkeith 01-06-2010 12:27 PM
The unibody is now getting powder coat, then it goes BACK on a dolly for panel fitment and exterior paint work.
drb930 01-06-2010 03:25 PM
Keith,
Where did you guys have that done?
I'm sure it is far away from me here in Los Angeles!
Thanks,
Dave
av winans 01-11-2010 05:08 PM
Thanks,
Dave
Very close actually, La Brea Tar Pits of course.
GaryR 01-11-2010 05:15 PM
So are those TWM 3006 throttle bodies? I like the individual design vs. the PMO bodies that aren't all the same (straight).
Buckterrier 01-11-2010 05:42 PM
Keith, very cool. I take it the phosphate is zinc and the ecoat is epoxy? I'll bet it's my product ;) We have about 75 - 80% of the tanks in north America.
euro911sc 01-29-2010 12:09 PM
Awesome build.. you guys started in 2007, essentially. It is now 2010. Have you been working on it continuously or were there long dry spells? what would it take to do this in straight calendar time? 6 months?
best regards,
Michael
eimkeith 01-29-2010 04:39 PM
Yes, long spells whilst work was happening on other significant builds, and a steady stream of cage building and racecar work for day-to-day business. Plus a little product company launch and nuturing...
- we stay pretty busy.
If the client wants a project like this to be a shop-wide priority, then 6-8 months start to finish is realistic.
dtakenname 05-09-2010 07:16 AM
Hi,
Any updates on this car?
What a project!
GaryR 05-09-2010 08:28 AM
Originally Posted by dtakenname (Post 5341318)
Hi,
What a project!
I would love to see a "ballpark" cost on the whole stripping/phospate/e-coating. What a fantastic way to begin, with an "as-new" base tub!
ERH 05-09-2010 02:06 PM
It's a roller now and going for paint.
Keith sent these a week or so ago following e-coat and powder.
http://forums.pelicanparts.com/uploa...1273439151.jpg
http://forums.pelicanparts.com/uploa...1273439179.jpg
http://forums.pelicanparts.com/uploa...1273439208.jpg
dtakenname 05-09-2010 03:58 PM
Hi,
I don't see any front fenders, going for e-coat. why?
Are you going to use F/G instead?
If so what are the advantages of using F/g front bumpers instead of steel?
Many Thanks.
Flieger 05-09-2010 04:00 PM
light weight :)
dtakenname 05-09-2010 04:18 PM
Yes, just why not use both front and back f/g to make it lighter?
I was thinking my be it's a better choice in C2-RSR conversion to go f/g front?
Flieger 05-09-2010 04:24 PM
Fiberglass rear fenders have cut-line issues unless you like Dzus fasteners. :)
http://forums.pelicanparts.com/uploa...1273447459.jpg
ERH 05-09-2010 04:26 PM
All steel...
The fronts were just off for e-coat.
