Blanco's Avatar
Porsche Crest yet another "It won't start" thread.. my 1982 911SC and help needed.
Esteemed gruppe!!
My old Permafail was going in/out intermittently and was confirmed by swapping out with a good one.
I decided to go with an MSD 6A for ease of installation and after reading tons of "no spark/start" threads.
I changed the green wire since it was cracked and frayed. I also changed cap/rotor with spark plugs since it was due.
All was good with the world after I changed the system out to MSD. It cranked up fine and I drove it down to the gas station for a fill up.
I got back home and proceeded to wrap the rest of the wires with electrical tape.
This is where the problems started. It will NOT crank now.
What would cause a no start symptoms when I began to zip up the wires into the loom???
Thanks,
Alex
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler
Old 12-13-2006, 03:17 PM
Hell Belcho
Nostril Cheese's Avatar
Check the yellow wire in the loom. I believe this is the signal wire from the key to the starter solenoid.
Old 12-13-2006, 03:27 PM
dweymer's Avatar
A loose conection? A short induced by the movement(this happened to me; car drove fine for 8 miles stop start red lights etc. then I come to a light, and poof, no more magic smoke, just died) I shorted my pertronix out.
Donnie
Currently Porsche-less.....
Old 12-13-2006, 03:31 PM
Blanco's Avatar
Originally posted by dweymer
A loose conection?
That's where I'm headed. Did you ever find out where your loose connection was?
I'm also checking the yellow wire that Nostril cheese suggested.
Old 12-13-2006, 03:34 PM
dweymer's Avatar
I was actually a small spot of bare wire right as it goes into the spade connector. Use heat shrink on all joints!
Check all your fuses to see if one blew.
Donnie
Old 12-13-2006, 03:40 PM
