Originally posted by bigchillcar
he mentioned the 'mail oil seal'..which one(s) do you think he might mean?
The RMS (rear main seal) is located behind the flywheel.
Originally posted by Don Plumley
I am particularly worried about the AWD system.
The 964 AWD is bullet-proof, it does not break.
I believe there are two sensors on it that cost $1K each and they do go bad.
The PDAS (traction control) uses a transverse and longitudinal accelerometer that also don't break but they do fill up with metal shavings as a consequence of the way they function. This prevents the internal pendulum from swinging so you open the sensor and clean out the shavings and you are good for another 100k miles. Some mechanics are not aware of the cleanout option and will swap out the sensors costing you $800-1500USD.
Original clutch means DMF not replaced
At 65k miles and 17 years old the premature failure of Freudenburg DMF is a non-issue.
Old 01-03-2007, 12:56 AM
bigchillcar's Avatar
Ryan, did your book deal go through or are you flying again?
paul: worse..got lazy and quit looking for a publisher after the last one just almost went with it. i went back to my first career out of college (ugh) doing research veterinary surgery (animal model) in stroke research at our local medical center. i'd rather lick a dead cat in the ass than show up here every day..
The lack of a dual distributor vent kit is a non issue. Just buy the kit for $15 to $20 and spend a half an hour installing it and you're done.
jay: thanks. that's what i was hoping to hear.
If I bought a pre 92 I would want a good deal on a well maintained car- something under $20k.
I might be able to find that, but it's going to have high miles under 20k. i've found a couple with low miles i could probably pick up in the very low 20's.
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 01-03-2007, 07:27 AM
Don Plumley's Avatar
Thanks for the clarification!
Don Plumley
M235i
Old 01-03-2007, 08:52 AM
And not that it matters any more but the LUK flywheel was never installed on the C4 at the Porsche production line (that includes MY94), only the C2 was given the new unit. The MY91-94 C4 received a modified MY90 Freudenberg.
Old 01-04-2007, 12:34 AM
