Machining 951 Fuchs backspace.
Came across this pic of the back of 7x16 915 Fuchs that clearly shows the profile. Has anyone ever machined back the mounting surfaces to, say the same as a 6" wheel backspace. Since so many people complain about rubbing in the front that would take care of it.
Would the fact that these are forged wheels keep you from doing so?
Ulrich
Ulrich
Old 01-05-2007, 06:00 PM
p911dad's Avatar
Ulrich, that is an interesting solution. Conservative ol' me says you will join the ranks of test pilots when you start removing metal on such a critical component, considering the stresses that a wheel on a Porsche can expect to receive. Perhaps a wheel expert has a different opinion.. Glenn
Old 01-05-2007, 06:27 PM
racer's Avatar
1) Those wheels are great because they allow you to run larger front calipers (think 964/944T) without running wheel spacers which push the wheel even further out.
2) You would be machining away the area where the lug bolts attached. Call me finicky, but I'd hate to find out under stress that the wheels would crack at their attachment points
Old 01-05-2007, 06:29 PM
David's Avatar
I've machined the hubs on wheels in a vertical boring machine, but looking in the bolt holes it doesn't look there's room to take any material off.
Old 01-06-2007, 06:47 AM
Somewhere in the Midwest
MotoSook's Avatar
I seem to recall that the 951 wheels have deeper set lugs, which essentially puts the same amount of material between the lug nut and the hub. Someone will come along and call BS or back that up, but I don't think you want to remove material from that wheel.
Old 01-06-2007, 06:54 AM
gumba's Avatar
An alternative I used for more backspacing was using a 912 hub. I think it's about 1/4- 1/2" narrower than a 911 hub. I used long studs and spacers to get the backspacing I wanted. Too much backspacing will cause the tire to rub on the shock cover (I removed mine). I had 930 calipers, 8x16 951's w/225 SO3's on the front on my '73 targa.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 01-06-2007, 08:05 AM
Really interesting. Would that be a straight bolt on? Forgive my ignorance, what years was the 912 built.
Thanks.
Old 01-06-2007, 08:21 AM
gumba's Avatar
Yes a straight bolt on. Not sure of the years.
Harold
Old 01-06-2007, 08:27 AM
KTL KTL is online now
Schleprock
KTL's Avatar
I agree with Souk. Despite the hub looking deeper, the countersunk lug holes establish a hub thickness (between the lug seating surface and the wheel mounting surface) that is the same thickness as a non 951 wheel. So machining the wheel mounting surface to make any sort of substantial gain in backspacing (reduced positive offset) would make the hub thickness at the lug holes much thinner. Probably not a good idea!
Kevin L
'86 Carrera "Larry"
Old 01-06-2007, 08:31 AM
Looks like 66-69 in US. It was introduced in 65 in Europe. I assume all part numbers start with 912. What about strut shock inserts, ball joints etc., will all the current stuff fit?
Thanks.
Old 01-06-2007, 08:49 AM
Wash. State
nesslar's Avatar
Thumbs down
Please don't. That just looks like "asking for disaster."
How about 50 series tires versus 55 instead? Or maybe people with rubbing issues can just raise the front of the car about .125-.375 of an inch. Shouldn't take much, usually.
Seems to me our cars look better with about .75, maybe an inch, or even a bit more of 'air' under the lip anyway. Too low just doesn't quite look right, just my $.02 this time.
Old 01-06-2007, 10:23 AM
gumba's Avatar
The 912 hubs are a straight bolt on. I used them on our targa (track/street car) for 3 yrs. before I sold the car. You will need to use some type of spacer as you won't be able to use the full offset of the 912 hub. These should be available from any Porsche recycle shop. You should just be able to ask for a 912 front hub.
Harold
Old 01-06-2007, 10:29 AM
gumba's Avatar
8" Fuchs on narrow body 911?
I responded to the 912 hub approach a few years back. Here is the link. If you go to the 2nd page I have a shot of the 911 hub compared to the 912 hub.
Harold
Old 01-06-2007, 10:39 AM
Are you talking about the machining of the wheel? Yeah, sounds like a bad idea after the posts here.
The 912 hub is an interesting idea.
Ulrich
Old 01-06-2007, 10:40 AM
Thanks, that clears it up. For some reason I was thinking strut all this time, hence my questions about shock inserts, etc.
Ulrich
Old 01-06-2007, 10:48 AM
Check out his diagram for 65-69. Do I need everything from the left of the spindle or just the hub.
http://dcauto.gotdns.com/catalog/index.php?mode=parts&model=911-1&year=1965-1969&group=4&section=402&illo=402-05
Thanks.
Ulrich
Old 01-06-2007, 10:52 AM
gumba's Avatar
Just the hub. I would also replace the wheel bearings so everything is fresh.
Harold
Old 01-06-2007, 11:30 AM
Just sourced the hubs from PartsHaven for $50 ea. At that price it'll be a fun experiment. Thanks very much for the idea.
Ulrich
Old 01-06-2007, 11:49 AM
Wash. State
nesslar's Avatar
Smile
Ulrich,
Yes to all you said in reference to my "...don't do it....". I certainly fear the machining. Or rather I respect the lack of it.
Old 01-06-2007, 12:34 PM
Hey Gumba,
Got some 912 hubs from a 68 and, looking at the pic below, they are not hubcentric for my 911 Fuchs wheels. Did I get the wrong year?
Ulrich
Old 01-12-2007, 02:53 PM
