| View Poll Results: what sizes would you like to see made? | |||
| 8" and 10" fitment for SC/Carrera & big brakes with some effort |
28 | 39.44% |
| 9" and 11" for a Turbo fitment |
27 | 38.03% |
| 10" and 12" for a Turbo fitment |
8 | 11.27% |
| 8" and 9" x 15 over 930 brakes |
9 | 12.68% |
| 9" and 11" x 15 over 930 brakes |
5 | 7.04% |
| Multiple Choice Poll. Voters: 71. This poll is closed | |||
LinkBack | Thread Tools |
Rating:
Cast Fuchs..what size would you like to see made?
Pick your desired wheel size and application. Vote for as many sizes as you'd likely purchase.
The unlisted sizes are 17". Moses is doing then...and they look like this is 7.5 and 9 x 17s which are sizes already being done for the SC/Carrera and big brakes.
you may want to put a link on the 930 forum to come over and vote.
Tru6 Restoration & Design |
Limbo
I want 9' and 10' for my SC..... I know, it will be a little more custom than most SC's.
Big ol built Duramax Durango R/T 19’ Current Custom project V8 M3 08’ Built and spoiled |
As a mass produced wheel I think the 7.5/9.0 sizes planned are the best course. Easy fit equals happy customers. These are the sizes I run on the track and have no complaints.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Skunk works
will 9's at the back fit a narrow body?
964 RS-4 |
7.5 and 9s are fine, but need 50-55 offset and brake clearance for 993.
I'll buy the original 7.5 and 9 x 17s that Mosers will be offerening myself but they aren't the most tire you can stuff under an SC/Carrera, 8 and 10 is.
Slider you'll never get a set of 9 and 10s under an SC fender but it is a good thought. The 10 can be tight in the back but the 9 is really too big up front.Even though you can't get the street tires that fill them out correctly any more a set of 8/9 15s look cool and be fun with sticky rubber! 9's won't go under a narrow body but an 8" will with some work. Jeff might be because you run BBS which are 7.5 and 9 Fikse's are typically 7.5 or 8 and 9 or 9.5s depending on when you bought them and also work fine with zero fitment problems.Jon sounds like Moses has already solved the brake clearance issues on the original 7.5/9s. He is using the Fikse on his car as a model. If so, there will be no clearance issues. Last edited by rdane; 01-17-2007 at 09:21 PM.. |
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods |
Actually I build my wheels to my own specs for offset and clearance and I faxed this info to Moses to use for brake clearance (brembo GTP)
![]() Cheers
If the first sets go over well, wider wheels (10", 11") are a very real possibility.
Administrator
Centers for 3-piece 18's?
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Also, going from early offset to late will require moving the entire center more than an inch within the barrel. Not trivial either. Last edited by RallyJon; 01-18-2007 at 06:45 AM.. |
SC/Carreras ARE early cars. The offsets/brakes changed in '89 for ABS. Early cars have 10-25mm offsets, late cars have 50-65mm offsets.
Irrationally exuberant
In front, 7.5" is the "safe" width but I run/ran 8" Ruf and Fikse on my Carrera. I'd buy 8&9x17 if I was shopping for wheels.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Limbo
rdane,
I have run 8's & 9.5's on my SC the way it is. I plan on building my car into an F-prepared PCA car so a little fender flaring (massaging) is permitted within the rules. That's how I plan on running 9's & 10's.
![]() (or add flares or get turbo fenders) With the right inboard offset, a 9" wheel on the front would stick out past the fender lip on an SC almost an inch.
'82 911SC racecar '05 WRX STi |
What about a 911R offset for us really early narrow cars?
-Britain
'69 912 w/ 2.3L Type-4 Turbo Engine '74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans. '80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks -- www.britainracing.com -- |
Limbo
jaydubya,
I have a buddy who is a body & paint guy and we are going to run a baseball bat under the fenders to stretch the metal and then hammer and dollie the correct shape back in to gain the 3/4 inch that I need. The other 1/4 inch that is needed was gained when I upgraded my brakes (993) and the hubs that I used moved the offset in a 1/4 inch. I have run 245's on the front without rubbing already, and I am just trying to get a 255 on a 9 inch wheel....
Sounds like a nice setup! Post up some photos when all the drama is over
