Super_Dave_D's Avatar
What does this wire plug into - HELP
88 Carrera
Today I noticed this connecter on the front of the driver’s side coming out of the console area. Anyone have any idea what it plugs into. It has 2 blue wires (one w/black stripe).
I have not noticed anything not working?? Can’t find anything unplugged?
Your help is appreciated
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 01-20-2007, 11:37 AM
audi2.7t's Avatar
Seat belt sensor?
'96 Dodge Viper
'09 Maxima
'05 zx10..(0-100-0 before your turbo even spools!!)
'99 Rottweiler
'08 Cane Corso
Old 01-20-2007, 12:00 PM
seat belt sensor is pluged in
2015 Audi S3
Old 01-20-2007, 12:38 PM
Walt Fricke's Avatar
Perusing Bentley shows a blu/wt and blu pair connecting the heater control unit for an '88 (the unit being nearby in the center area) to something called the inside temperature sensor blower, which I deduce is a module where a small motor and fan (powered by a brown ground and a red/wt power wire from the fuse block) blow air over the sensor connected to the blue wires. Looks like this refinement came in with the '86 models.
I don't know if this is the inside temp sensor (previously located up by the rear view mirror) now located just to the left of the dash heat/fresh air levers behind a two slot plate, or something else. And this shows connections only at each end. The nearest end would be at the heater control module. So you might pull back the carpeting and see if this will reach back and up there and fit some unused two pins. Or maybe the wiring diagrams don't show intermediate connections any more, and the disconnected one is on a wire pair just forward of the control console.
Just guessing, you understand. Maybe someone who knows the car well can identify it.
Walt Fricke
Old 01-20-2007, 01:45 PM
mine didnt come with the auto temp option
2015 Audi S3
Old 01-20-2007, 03:42 PM
anyone?
2015 Audi S3
Old 01-20-2007, 06:40 PM
dorschman's Avatar
here are a few more to confuse us further
I still am not sure what they do
these are from my first head unti install. Actually I am currently putting in a Becker cdr-220. I never did find out what those connectors do.
87 911 coupe "Katy"
Summer Yellow
Linen Mahogany interior
04 Pilot "The Pilot"
Old 01-20-2007, 07:14 PM
I know someone has their console out
2015 Audi S3
Old 01-21-2007, 04:06 PM
pgeorgeson's Avatar
Dave: Thanks for your help on the removal. After some further work, I got it. Unfortunately, I didn't see anything in there that looks like that connection.
1964 356 C
1970 911T
1974 914 2.0
1986 Carrera Spec911 race car #76
1990 Carrera 2
Old 01-21-2007, 05:25 PM
my last attempt at trying to figure this out.
2015 Audi S3
Old 01-22-2007, 06:42 AM
dorschman's Avatar
if it helps at all mine does have the autotemp controller between the seats and it seems to work without the blue wires plugged into anything.
87 911 coupe "Katy"
Summer Yellow
Old 01-22-2007, 07:37 PM
david914's Avatar
Two guesses. One would suggest that the wire is part of the dash illumination circuit due to the wire colors. Another guess would be that it's part of the central locking system.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 01-22-2007, 08:44 PM
echecsqueen's Avatar
Did anyone ever figure this one out? I have the same blue /white and blue pair..not connected to anything. All carpet is out. My heater is not working. Any clues? The door locks work but the button doesn't light up.
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 05-07-2017, 03:08 PM
