Twins are more fun!
JMA-RUF's Avatar
Question Motronics: Testing for leaky injectors?
I suspect I have a leaky fuel injector in Cyl # 1.
How do I test/verify whether the injector is in fact leaking?
The plug is sooty and wet and I suspect it's wet from a leaky injector.
James
Carrera TT
(3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's)
Old 01-28-2007, 07:29 PM
The only way I know is to pull the injector rails out far enough to observe for leaks.
Other than that, I would replace the #1 ignition wire and spark plug and see if that takes care of it.
Cheers,
Joe
Old 01-29-2007, 08:52 AM
I have the same concern and just this weekend pulled all six and sent them to WitchHunter Performance for flow testing/cleaning. I have been running a little rich and think it may be a leaky injector or two.
If nothing else, their service should give me a good baseline for my 200k+ mile injectors.
Mark
'88 Carrera GPW Sunroof Coupe
'82 SC Targa (RIP)
Old 01-29-2007, 09:32 AM
Don't know where this leaky injector causing rich condition myth comes from but the usual condition is clogged injectors resulting in a lean condition.
Rich conditions are usually remedied by mixture adjustments on the AFM CO mixture screw etc.
Chers,
Joe
Old 01-29-2007, 12:01 PM
doug petty's Avatar
I've got an 85 that was running rich & finally sent all 6 to witch hunter for a cleaning, @ 175000 miles 3 were shot, the pintel tips were worn down & wouldn't seal. replaced all six & life is real good. just tap the key 1st thing in the morning fires right up.
doug
85 911 cab - red
ongoing work in progress
Old 01-29-2007, 12:14 PM
Mythbusters R Us
Here's one quick excerpt now:
Leaky Injectors
Wear in the injector orifice and/or accumulated deposits can sometimes prevent the pintle valve inside an injector from seating, allowing fuel to dribble out the nozzle. The extra fuel causes a rich fuel condition, which can foul spark plugs, increase emissions and cause a rough idle. A carbon-fouled spark plug in one cylinder of a multi-port EFI engine usually indicates a leaky injector. If cleaning fails to eliminate the leak (which it can if dirt or varnish are responsible), replacement will be necessary.
Found here.
YMMV.
Mark
'82 SC Targa (RIP)
Old 01-29-2007, 12:18 PM
