(the shotguns)
How to remove surface rust before painting?
I got my watershields back from the beadblaster and a light 'haze' of rust is present on them (not completely covered but still need to get rid of it). What should i use to clean this off prior to painting?
Also, should i prime before painting? I plan to use a low gloss high temp paint. thanks!
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Slippery Slope Victim
Try this product by Eastwood.
http://www.eastwoodco.com/shopping/product/detailmain.jsp?itemID=11122&itemType=PRODUCT&iMainCat=379&iSubCat=380&iProductID=11122 Yes, you should use self etching primer. Eastwood makes a fantastic primer. Good Luck
MikeČ 1985 M491 |
Yes you should prime bare metal. For surface rust you can use PickleX, the POR 15 product called Metal Ready or the PPG metal prep product called DX520 or Ospho (http://www.ospho.com/). Use google on the rest. Hope this helps.
Robert Williams 70' 911T |
PickleX Epoxy prime and finish with the top coat of choice, no more rust worries.
If you use PickleX you can't use an etch primer. Don't know about the others.
Classic 1969 911T |
