Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Englebert...I am doing the same rocker panel replacement, and it looks like I have to take a donor chunk slightly further back like you did. Did you document your process when you did it? I'd love to take a look.
Thanks!
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 02-26-2007, 03:57 PM
Carmagic.us
rothaus's Avatar
Thanks!
Hi,
I actually cut out the piece you see missing. and I welded it back in. I added a backing strip on the back. About a 3/8 wide piece of sheet metal. It helped to align the piece.
You have to be careful weling in the piece, just go slow and don't try to weld it all the way at the time, or it will pull in a dent.
Good luck.
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 02-26-2007, 05:58 PM
19 years and 17k posts...
azasadny's Avatar
Engelbert,
Great work there! Welcome aboard and thanks for the pics!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 02-26-2007, 06:40 PM
Rennch on YouTube
rennch's Avatar
Englebert...Why did you cut it? Is it just easier to get to the rocker that way? Do you have any other pics of the rocker replacement? You can send anything you want to porscheparts@whirledmedia.com if you have a few.
Michael O'Neal -
Old 02-26-2007, 07:19 PM
Send a message via Yahoo to Larry_Ratcliff
Wow nice looking work are you a body man by trade?
Old 02-26-2007, 07:44 PM
Carmagic.us
rothaus's Avatar
The rocker panels go actually under the rear side panels, and they are welded on to the frame piece you can see on the image where the piece is cut out. I just welded it back in with a backing strip, since I had a gap from the cutting wheel. You have to be careful welding or the sheetmetal will deform.
I also had to add a piece between the rocker panel and the side panel since the side panel had thin material because of rust at that spot.
I normally cut out the rusted pieces and not only patch over it, as you can see.
I will post more pictures as I go along.
Old 02-27-2007, 09:56 AM
Carmagic.us
rothaus's Avatar
Exclamation Update on the Project 911T
Update !
Got the frame between the front hood and the wind shield done, and also the bottom corners of the windshield frame.
Cut out and replaced the section where the fender mounts.
This weekend I cut out the rear portion of the floor pan.
More to come
Cheers
Engelbert
Old 03-10-2007, 05:04 PM
gigem75's Avatar
wow
Old 01-10-2008, 06:11 PM
lateapex911's Avatar
what are you doing for corrosion protection and finishing in the hidden areas, such as behind the rockers?
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 01-11-2008, 05:14 AM
Very impressive. What are your plans for the tub as far as coatings? After browsing the latest RSR thread, I would probably see about having the tub baked to get rid of all the goo and then coated for corrosion resistance. It would be reassuring that all that hard work would last as long as possible.
Old 01-11-2008, 06:39 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
any updates here? fantastic work
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 05-16-2008, 10:56 AM
Carmagic.us
rothaus's Avatar
Here is the last update
Update on my Project 911
Cheers
Engelbert
http://carmagic.us
Old 05-16-2008, 02:13 PM
