Racer
Woo Woo! Engine out. Fixing leaks, rear suspension, etc.
After struggling for quite some time with undoing the hard oil line at the rear of the engine, I finally got that undone over the weekend and I dropped the engine tonight. Now to fix (all?) the pesky oil leaks!
Preston Brown Street: 2009 911 Carrera S Coupe | 2015 Cayenne S | 1995 Audi ÜrS6 (unicorn) 1965 356 C Coupe | 2010 F250 (support vehicle) Race: 1994 964 GT2/1 | Various 944s | 2016 Superlite SLC | 2007 997 Carrera Last edited by preston_brown; 02-17-2007 at 06:59 AM.. |
Will program for food
Good job. It really is not that bad of a task - once everything is disconnected... Watch out for the dreaded while-you-are-in-there ...
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
Watch out for the dreaded while-you-are-in-there ... it seems once it's out and on a stand there's suddenly a LOT of things that you might as well do . my couple of oil leaks has turned into a shortblock and a couple of big pelican orders. hoping to have it running by april 1, maybe. Don.
Good jub, did my first engine pull about 6 months ago.
There seems to be no limit to the amount of money you can spend on these cars we love so dearly. Oil leaks lead to tearing things aparts, cleaning leads to painting, painting leads to tearing more things apart, tearing things apart require need new orings or gaskets. Since the motor is out I better replace this bearing and that seal, may as well send the injectors off for cleaning since I tore the intake apart to clean and paint, new plug wires would be nice, better get a cap and rotor while I'm at it. I could go on and on, funny thing is this is just the last two weeks of my full rebuild of my 3.2, it's been going on for months. Compared to the rebuild the above is childs play. I'm not complaining because its a lot of fun, just funny, wifes not laughing though. Good luck Brian
1987 911 Coupe-Current ride 2007 997TT-Sold 2006 997 C2S-Sold 1991 964 Turbo-Sold 1987 911 Targa-You never forget your first |
Welcome to the club. I did mine in October and I am still having fun with it. But now as the weather improves I am moving quicker.
Congratulations!
James 1969 911E Slate Grey 1981 911SC Wine Red 1997 911C4S Ocean Blue |
somebody actually bought and used that "body paint protector?"
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Not Quite Banned
Good job Preston. Take some pictures as you go along and then complete the post when you put the engine back in.
yelcab1 - I have one and have been using it for close to 25 years...
Thomas Owen 1972 911T 1972 911S |
19 years and 17k posts...
Preston,
Congratulations! Once you've dropped and reinstalled the engine, you have much better knowledge of the things to look for and oil leak problems. Clean everything up and replace old hoses, clamps, etc... anything that you have a hard time getting to when the engine is installed.
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Nice going, Preston... was this a solo job…?
~~~~~~~~ My last engine swap was in an old Triumph TR4 -but I had Mothers’ help…! Yes, my Mother was a farmer’s daughter (a feisty Russian partisan wearing Army boots) Cheers, Jascha
1995 993 ('Under my Care') 1989 911 ('Go Pitt') 1996 993 ('Go Navy') 1984 911 ('Go Pelican') |
Nice job Preston,
If you need a hand installing the engine, let me know. I am thinking about doing my first solo drop when needed and any experience is good to have
61 VW Karmann Ghia 63 European Bug 75 Carrera Coupe 2.8L #81 75 911 Targa 2006 Cayenne S Titanium |
MBruns for President
Good for you Preston! now start cleaning that bad boy up!
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
good job preston. i would like to do that some time in the future. any advise. thanks.
Preston,
Congratulations ! Nice to see another Tar-heel at work
John D. 82 911 SC Targa-Rosewood 2012 Golf TDI |
Racer
From the looks of it, the major oil leak is from the temp sender, but I suppose there are probably more than one. I'll definitely take pictures as I disassemble and update the thread as it progresses. -- Preston
Preston Brown Street: 2009 911 Carrera S Coupe | 2015 Cayenne S | 1995 Audi ÜrS6 (unicorn) 1965 356 C Coupe | 2010 F250 (support vehicle) Race: 1994 964 GT2/1 | Various 944s | 2016 Superlite SLC | 2007 997 Carrera |
Good job on the first engine pull Preston. Make sure that you replace the thermostat oring too when you are replacing the oil pressure switch. 999 707 314 40 is the part # for that. Are you going to separate the trans. from the engine? You should if had not already planned to do so. Main shaft seals on the G-50 boxes go bad occasionally. Take a good look at the clutch and flywheel seal too.
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE |
Sweet. I wish I were there to have watched the operation. How many hours did it take?
_______________________ Unless you change your course, you are likely to end up where you are headed. '87 Carrera, Black on Black |
...and be honest.
Wow!! Solo drop, you got big'ens. Nows the time to sell it to me and get that 3.6.
1974 911s "It smelled like German heaven" http://www.youtube.com/watch?v=6ySt9SeZl9s |
Nice job On the oil line I used a 14 inch pipe wrench very carefully. It came loose no problem. Oh well, next time Jim
Nice work, Preston! I like the look of your tool chests. I'd bet you don't need a LOT of help but if you do just give a yell. Several of us are close and don't mind giving a hand if you need it.
07 Audi A4 2.0T Cabriolet - Black/Black (sold) 96 993 C2 Cabriolet - Arena Red/Tan (sold) 82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold) 58 DKW Universal - Baby Crap Yellow/Beige (sold) |
