Porsche Junky
So what kind of suspension mods are required? and what kind of brake mods? I want the conversion, but I also what to know what I have to upgrade to handle the conversion
At the minimum.....sway bars, torsion bars and depending on the cars current condition, struts and shocks.... Search these topics for products that suit your use and/or pocket book.....
1986 930 RUF equipped |
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
But do you have to upgrade due to the extra weight or due to the power?
1982 SC.....currently undergoing the 3.6 conversion. 3.6 is sitting beside the car so far. |
Administrator
I'm pretty sure a 3.6 weighs less than a 3.2, once you lose the parts not used in the conversion (stock flywheel, power steering, stock exhaust). The only essential upgrade is oil cooling.
Brakes and suspension are upgrades for tracking a car that you've made faster than it used to be. For street use, stock components will be fine. Lots of guys have done it that way. And even if there's a net weight gain, it's a lot less than adding, say, a passenger (and for the record, even running with a very chubby co-pilot doesn't mean you need new torsion bars or brakes).
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
HAHAHA, that is very true. Thanks |
Somatic Negative Optimist
in_style:
What year is the 3.6 ??
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
The 3.6 is out of an 94. He has two of them. And one out of a 98.
'94 is good but, can you get some numbers like mileage and leakdown?
Will the seller give you some warranty if you install yourself? Is a clutch included? HE and muffler? Tin ware? Two things never change in Engineering: It'll always cost more, and take longer than estimated. Even if you don't beef up your brakes and suspension, what you have now most likely needs attention. Caliper rebuild? Hoses? Struts and shocks? tie-rods? Tires? CV's? All bushings on swaybars and T-bars? 4-wheel Alignment? Corner balance? A 911 is no fun to drive with sloppy components and a bad alignment. In fact, it's dangerous. What I am trying to say is that there is a lot more to it than just installing a 3.6. Consider all the other stuff and the cost. If you feel that you have it under control and can do what's necessary, go for it and have fun.
