Guest
Posts: n/a
Power window motor question
Are the later motors more powerful. I noticed that a C2 window operated faster than a 78SC. Somebody told me that the C2 PW motors might be more powerful...true?
Joe Garcia 86 Carrera |
Guest
Posts: n/a
I had two very slow electric windows. Then I lubricated the mechanism in one of them. Now I have one very fast window.
27 years without grease will slow just about anything down. ------------------ Jack Olsen 1973 911 T (3.6) sunroof coupe |
Guest
Posts: n/a
Jack,
What part did you lubricate? The gears, felt channel or both? What did you use to lubricate it with? Thx, JoeA |
Guest
Posts: n/a
Joe, I lubricated the gears with grease, as well as everything I could get to that moved (including all the trapezoidal stuff). I used a graphite based powder lube on the felt runners, but I don't know that that did any good. The window runs like it has a new motor, now.
Guest
Posts: n/a
Jack, how did you access the motor
and trap stuff? Thanks |
Guest
Posts: n/a
I took the inside panel out (as well as the handle, cap piece, etc.).
Guest
Posts: n/a
Jack...I took your advise, greased the heck out of everything that moved and its going up fast now.
Thanks, Joe |
