I'd like to add a couple things. First, these screws can be a royal pain in the a** as others have suggested, so don't feel bad.
Realize that there is an over-center effect when installing the lights, of sorts. You hook the top of the light onto the top of the fender than rotate it down. It should "pop' into place if all is well and you'll definitely feel it. Once you have it firmly in place, use an awl or some other probe to check the left/right alignment of the hole in the trim ring with the hole for the screw. If things are not lined up perfectly, remove the light and re-fit it. Do not attempt to install the screw until the holes line up. If you try to install the screw before everything is lined up, you'll likely cross-thread it.
Once you are happy with the alignment, place some tape on top of the front bumper and get a long screwdriver with the proper size tip. I use one around 15-18 inches long. The angle the screw needs is such that the screw driver will come close to touching the bumper and you wany a screw driver long enough to get your hand out of the way so you can get the angle you need.
Go slow and make sure the threads are clean and lubed.
JR
Old 03-08-2007, 12:29 PM
SCWDP911's Avatar
Thanks, the picture did it for me. I will give that a try after I chase the threads.
Shane
- 1984 928S
Old 03-08-2007, 12:33 PM
kwm kwm is offline
God is nothing easy on these cars. I am getting ready to do this mod in a few weeks and the directions said it takes 20 mins max to do both lights?????? I am starting to really question that ad.
83SC black on black
01 Chevy S10
08 Buick Enclave
Old 03-08-2007, 12:48 PM
PSJoyce's Avatar
I had the same problem mounting H4's (well, getting the original sugar scoops off the 22 year old rubber seals was the first problem) and used the same techique as nesslar successfully. With the H4 trim ring in place on top, I could not hold it down in proper alignment with the screw hole.
I intalled the Sucro relay first -- wouldn't go without it even with stock lights.
Paul
1985 911 Carrera
Moss Green Metallic
Steve Wong Chip, WEVO shifter & PSJ, Kuehl Air Conditioning
Old 03-08-2007, 01:18 PM
buttjoint's Avatar
V8 ranch How can you be in jackson ? I see palm trees ! My wife was born in jackson, And I go back there a couple of times a year, I always stop at gus's and fill up on the fried chicken. I have a satin red metallic 89 cab Jim
Old 03-08-2007, 02:19 PM
SCWDP911's Avatar
lmbo
You got me Jim. I am originally from San Clemente, CA. We moved out here due to my work. I bought the car from a firend oif mine out their in the OC. I actually just cleaned her up adn posted some new pics a few minutes ago. Might look a little more like Tennessee to you!
Good catch though - although you'd be surprised at how many people here grow the banana trees!
Shane
- 1984 928S
Old 03-08-2007, 03:07 PM
Nashville84Cab's Avatar
We've been having gorgeous weather in TN!!! I need to take my top down and drive.
Darrell
1984 3.2 Carrera Turbo Cab - Protomotive chip, B&B Headers, M&K Exhaust, Garrett GT30, Tial WG (46mm), Custom Intercooler, "Big Reds" 993TT brakes, In-Your-Face Gauge Boost/AFR Gauge, and Removable Hardtop
Old 03-08-2007, 08:08 PM
SCWDP911's Avatar
it was a LITTLE cool this evening on the drive home! Ah, who cares? That is what a jacket is for, right?
Shane
- 1984 928S
Old 03-08-2007, 08:13 PM
kwm kwm is offline
Speaking of the Sucro realy PSJoyce and others where did you mount it in your instal?
83SC black on black
01 Chevy S10
08 Buick Enclave
Old 03-09-2007, 04:01 AM
holtjv's Avatar
You should paint those rings--will look like they belong on the car then.
Warren Hall (Early S Man), 1950 - 2008
2006 Tri D675 Scorched Yellow
2006 Ducati Sport Classic mono SOLD
1979 SCWDP #0020 Talbot Yellow SOLD
Old 03-09-2007, 05:30 AM
PSJoyce's Avatar
I used one of the screws at the lower front of the fuse box. I've got photos at home, but there are several photos of installations here on the forum. I had to extend the ground wire to reach the common ground point just to the rear of the fuse box, but otherwise, all wires and the relay itself were just perfect.
Paul
1985 911 Carrera
Moss Green Metallic
Old 03-09-2007, 06:29 AM
