Help! Engine Speed Sensor Connector?
I've had some intermittent trouble starting my '86, particularly when cold, so I started checking around and found this
This is the connector for the engine speed sensor. The left-most connector pin in the pic is mangled as though it wasn't seated properly and forced into place. I suppose it's safe to assume this could be the source of my problem? The head temp sensor checks out fine per ambient and running measurements. If nothing else, I need a replacement connector pin. I'm hoping our host has them. Going to look now...
David Dryden '86 911 Coupe '05 BMW X5 4.4i |
kayjaco and eagle day both sell the connectors and pins. I don't think Pelican sells them but I could be wrong.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
