Guest
Posts: n/a
Unstable rev's when cold- 1 solution
I was sufferring with a common problem it would seem for Carreras at least.
When cold the revs were all over the place. I printed out all the helpfull threads suggested by Warren & Co. but descided to try the easiest first!. How sensible! ![]() I removed and sprayed with an aerosol (proper) 'electrical cleaner' all the plugs/sockets I could find incl. the Head temp sender. As I cleaned all, I have no idea which was the culprit. But as she runs sweet, don't care!. ![]() Thanks Guys! Ben |
Guest
Posts: n/a
Ben,
Unstable rev's on DME engines is often caused by a bad air mass meter. This will cause the idle to "bounce" when cold. You can test yours with an ohm meter between 2 of the pins (you'll have to look up which pins and what ohms) However, if what you did worked, go with it! Nick. ------------------ __________ Nick Shumaker 1982 911SC Coupe [This message has been edited by Nickshu (edited 01-14-2001).] |
