Question Help please 89 carrera start problem
hi guys i have searched the forum and cant find the answer im looking for, so can you please help!
89 carrera turns over but will not fire.
renewed DME and starter motor, however if i push the car 5 metres it fires up.
Theres no spark to the dizzy.. DME working fine, fuel pump engaging, green wire is in v good condition..
can you please help identif what the problem may be?
Thanks guys, any help you can give me would be great.
Old 03-29-2007, 08:59 AM
Just to clarify...when you say "DME" are you refering to the relay or the actual unit? I had some problems similar to this on my '87 and it turned out to be a broken solder on the DME unit itself, however the relay had been replaced.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 03-29-2007, 10:54 AM
Hi i replaced the actual DME relay... sorry to sound dim but wheres the DME unit? Is it under the passenger seat as well?
Old 03-29-2007, 10:56 AM
