SCWDP911's Avatar
CIS mixture adjust screw question
I know what to do, just can't seem to find the "hole".
I have the hole already to access the screw, however when I "prod" around in there with my 3mm hexhead wrench, I can't seem to "connect" with the screw, at least not definitively. Is it a straight shot down, or off to the side, angled? Any assistance is appreciated.
Old 12-01-2006, 04:06 PM
straight down. the allen hole can get filled with dirt, so ream it out with a stiff piece of wire or something like that.
206 637 4071
Old 12-01-2006, 04:20 PM
SCWDP911's Avatar
Thanks, I will try that...
Old 12-01-2006, 04:27 PM
T77911S's Avatar
u have to use a long allen, not one of the short ones
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 12-02-2006, 06:12 PM
FinallyGotOne's Avatar
Your allen wrench should be about 4 inches long. I did this to lean out for emissions. If yu need a picture I 'll take one for you.
1979 911 SC
1974 OEM 911 Exhaust and Muffler - Modified to a 2-out
Fiberglas Goodies, 17" C4 Cup Wheels
Old 12-02-2006, 07:08 PM
I would love a picture if one was available.
Old 04-02-2007, 10:44 PM
emac's Avatar
Finallygotone
No pun intended,, but at best this is one of the hardest holes to get into.
So without being able to see anything how are you going to take a photo. Unless you have your engine out of the car.
Ernie 81 SC
Old 04-03-2007, 05:01 AM
Hey V8,
I had the same problem and found out later that the previous owner's mechanic put a drop of locktite on the screw and gunked it up. I had to use a dental pick and patience to clean out the hole.
BUT, here is the easiest solution for starters.
You need to take off the air filter and hold up the sensor plate (support the plate bar not the plate!) while you try to get the allen wrench to stick in the screw. With some downward pressure you might be able to get the allen in deep enough to make your adjustment.
I am using the same procedure now everytime I have to make an adjustment.
Should work okay.
Bob
73.5T first CIS!!
Old 04-03-2007, 05:11 AM
SCWDP911's Avatar
Thanks Bob
Shane
- 1984 928S
Old 04-03-2007, 05:31 AM
