subscribed
@wheeldude.com
if we need to have a couple of offsets. it will not kill the project.
catching up on thread reading ![]() -sd |
I have Lyndseys 5.5" backspace up front on 17x9 and 7" on back on 17x11 with original spacers on the 930 = no problems at all.
Crotchety Old Bastard
That is what you need to use. I have had many different 930 wheels on my 911 widebody, from 15" to 18". They all have that offset in the 9&11 widths and fit a stock 930. The width and offset needs to be the same no matter what car is using the wheels. It should be up to the owner to adapt their car to this standard. You will get yourself into a mess trying to fit every configuration and tire size. Set the standard and sell spacer and stud kits for the rear.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Just curious, how thick is the factory rear spacer?
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Early 930 is 2", I have heard the 965 is different due to rear suspension but have not seen it for myself.
Thanks!
Mine came with 28mm on the rear and 22mm up front. I ended up swaping them, and works better for me.
the rear one used for all '75 -89 is 930.341.611.04, 28mm is about right but it would be nice to get some other feedback, exact measurement is difficult to get. I have heard abot the ~2" ones but never seen them.
I think this would be a good business opportunity for you guys as well - essentially undersell every 3pc hacked up Fuch out there and make a decent profit at the same time. Honestly, I was starting down the path to have centers done in either China or Australia but I just simply do not have personal time to do this and maintain my regular job. I need 16" diam for mine to work with the specific race tires I want to buy. Might be a way to make a center similar to the 16" Fuch and can use with either 16" halves or the 17" halves Lindsey (and others) use. I didn't get that far in my search... I don't have time to wait for this option so I am buying Kodiaks, but if you had a 16" 3pc option you could charge about the same $2K and clearly make money and I would have bought a set for sure. I luv the look of the Fuchs but won't pay for it and then have a center crack anyway...
Tim www.negativereinforcementracing.com 1972 914 1.7L turned FW190-V8 353cube 525HP SBC with Mendeola S4 transaxle |
Never seen a 2" spacer from factory, but if use it implies that the studs would be very long and consequently take a lot of punishment... prompt to failure?
Administrator
Subscribed, with an inspirational photo:
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Sports Purpose 911 Driver
I like the new exhaust tips Jack, I had gotten used to the black out look but this is cool too. Was this a result of your trip to run Laguna?
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
Administrator
My exhaust outlets have always been raw aluminized steel (at least, since I got rid of the B&B muffler and the stainless tips). They get darker with time, but only the muffler and inlet pipes are painted.
They're fresher in this picture, I think, because they had to be replaced after this happened at Sears Point.
dude I remember that post, man that sux. I designed my tips based on yours, they are stainless but not sure how bright they will stay. since I did 1300 miles last weekend they've gotten a bit darker
My trip to see 911teo's beast!
I would only worry in the case of pure shear at high loads like drag racing with slicks. The shock of launch breaks off studs and that is why most of your 10sec and faster cars start running 5/8" diam studs. In road racing, you usually don't create that kind of launch or shock... instead you leave the guy waving you on the track fast but not "launching" - at least you shouldn't as it would be a bit disrepectful and possibly scary for the flag guy standing down there waving you on. I am ordering custom wheels with about an inch of additional backspacing so I can mess with track widths and such with spacers for instance - for additional tuning on the car.
I have several stock 930 rear spacers in the garage. They are all 50mm, don't know what year(s) they were used on. None of my Porsche manuals reference the spacer sizes used on the 930. Does anyone have such factory information?
As for long studs and spacers, they are very very stout when bolted together. Much better than using adapters in my opinion. I've ran that setup on 2 different cars for 15 years with no issues.
7.0:1 > 11.3:1 > 7.0:1
Quote from Bill V. "The front before '81, 930.341.611.00 was definitely 21mm.
the rear one used for all '75 -89 is 930.341.611.04, 28mm is about right but it would be nice to get some other feedback, exact measurement is difficult to get." Three experiences with 78 - 79 930s which all had 21mm front and 28mm rear spacers. |
