randywebb's Avatar
8 mm triple square 'socket'
I know of two places on our cars that use a triple square tool (like an Allen) - the door striker plates & the flywheel bolts (at least on the 3.2L motors).
But what size do they take? Is it 8 mm or 10 mm?
I'm asking because I have a chance to buy an 8mm one for a decent price used but don't want to do so unless I need it for the car.
Thanks.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-15-2007, 10:41 AM
Friend of Warren
I can't remember either. I think it is 10mm. Either way, Sears sells them.
Kurt V
Old 05-15-2007, 10:50 AM
Door Striker Question
Old 05-15-2007, 11:00 AM
The flywheel tool is 12 mm.
For what it's worth, Targa top latches employ triple-square bolts (can't recall the size).
Brian
Old 05-15-2007, 11:11 AM
vash's Avatar
triple square? is that what it is called? damn, i have been calling it the "12 pt, similar to a torx/ allen socket, thingy".
poof! gone
Old 05-15-2007, 11:25 AM
On my car, the flywheel bolts were 12mm and the pressure plate bolts were 10mm. They both were a biatch to get off. Personally I think triple square sockets are idiotic and should be banned. What is wrong with a hex nut????
1972 911T targa
Old 05-15-2007, 11:35 AM
randywebb's Avatar
Triple Square is stronger. Never use a Torx (or Bristol spline) both of which look similar - none of these interchange.
Thanks for the answers:
8 mm triple square - door striker plates
10 mm triple square - clutch pressure plate cap screws (some years)
12 mm triple square - flywheel cap screws (some years)
Old 05-15-2007, 11:39 AM
304065's Avatar
Don't forget the CV joints, although in later years, Porsche went to hex, which requires more fiddling with your torque wrench when you tighten them up.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-15-2007, 11:52 AM
Senior Member
triple square - a square has 4 corners * 3 = 12 points
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 05-15-2007, 11:59 AM
vash's Avatar
so a square 12mm wide, will fit inside that shape? all the points are right angles?
poof! gone
Old 05-15-2007, 01:27 PM
pwd72s's Avatar
The door striker plates are 8mm triple square...
Old 05-15-2007, 02:09 PM
