Banned but not out, yet..
The finally completed project
An air cooled refrigerator. ‘Mein Teil’ |
Looks great Rick!
'67 911S '69 911S, '70 911ST '73 911T Targa Signal Yellow '78 911SC backdate |
Old thread, but an interesting concept if it could be used on my '88 coupe.
Has anyone installed pop-out windows on a late model 85 - 89? Is there an actual kit available? I have the pop-outs on my '70 VW bug and they really do improve air flow. Would be a neat item to have on the Porsche as well.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
Pop Out Quarter Windows
Thanks to all who took the time to contribute to this tech thread. I need to complete this project soon.
Now in Florida !
Location: York Beach, Maine and Anastasia Island, Florida
Question about the B-pillar tabs
So, waking this thread up. Looking at Techweenie and Clay-O's photos in this thread, you can see two sets of tabs protruding from the slots in the B-pillar, on what is assumed to be a pre 1977 car originally equipped with pop out quarter windows.
Now, its been about 30 years since I have removed a 911 pop-out quarter window, but I seem to remember that those tabs were tapped to receive the flex-hinge retaining bolts. This allowed those tabs to act as a clamp, securing the flex-hinges of the quarter window. Those tabs do not appear to be present in the later cars once the spot welds are drilled out and the later B-pillar sheet metal removed, although the slot is certainly there. Which brings me to my question. What IS there in the later B-pillar that is sandwiching the flex-hinge of the quarter window? Are you simply running a sheet metal screw into an inner piece of metal in the B-pillar?
1983 911SC Coupe Hot Rod - Platinum - Twin plugged 3.4, DC-60 cams, PMO 50's, 1 3/4 headers, Bill Rader 915 w/LSD 1976 914 2.0 Lime Green Metallic - Completely stock |
The plates are still there under the spot welded L-bracket. The little tabs on those plates were removed, presumably to accommodate the new L-bracket. I don't believe the tabs did anything other than make it a little easier to slide the hinge into their slots.
As mentioned, the plates just need to be tapped. As for the c-pillar, my 83SC didn't have these plates. Some have used riv-nuts in the through-holes in lieu of the missing threaded plate. It wouldn't seem to allow for any adjustment but maybe not necessary. The early interior/exterior trim pieces need to be sourced as well. Hope that helps. Tim K |
Now in Florida !
Thanks Tim. That's good news. I had already sourced all of the parts needed, including all of the trim, screws, etc. It's interesting that the plates are still in there on the later models. It's also surprising that they bothered to change the stamping of the plates, removing the tabs, rather than simply eliminating them. My guess is that the plates lend a structural aspect to the B-pillar.
Thanks again.
Bottom line, I removed the pop-out quarter windows last Fall for an interior rework and now can't find the bolts that screw into the B-Pillars. Anyone happen to know what size they are?
Install pop out rear quarter windows |
"10. Screw in b pillar bolts or screws." Was just wondering if someone might know off hand. Went through my Haynes manual and couldn't find it. Guess I'll just buy a bunch and try 'em all! |
I have all of these parts if someone is interested in doing this project...
I have them for sale in the 911 classifieds section... lmk, thx, Bob fs 3 pairs Rear Pop Out Windows, latchs, trim, verticle posts, pair Windows Long Hood
I live for 911 tweaks... |
Old thread here, but hoping someone can help. Can anyone comment on the size of screw or bolt that goes into the B pillar?
subbed
Wanting to do this project on mine! Any wind noise increase going from a fixed to popout window? Assuming not if properly sealed. Thanks! Nice writeup as well!
Sorry for bringing up an old post but this mod has to be done.
I have a SC and as they didn't come factory with pop out windows what do I cut ? A slit in the B pillar to allow the "hinge" to sit hard up to the B pillar or C notch it ? Thanks again for the desired direction. ![]()
you need to drill out the "L" part of the pillar. At the end you will have two pieces like the ones in the picture below.
