johncmng's Avatar
Porsche Crest Am I installing the distributor correctly (pics)
Am I installing the distributor correctly. I set the pulley to TDC and I can't get the rotor to point exactly to the top marking on the rotor body.
Thanks In advance
John
3.2 Carrera
Old 05-23-2007, 08:57 AM
Friend of Warren
You have the crank pulley on the BTDC notch. It needs to be set at the left notch "Z1" which is TDC on the 3.2.
Kurt V
Old 05-23-2007, 09:20 AM
John,
What is it that you are showing in the 3rd picture? Is the 3rd picture showing the timing mark set at 5 deg BTDC with the rotor pointing exactly at the scribe mark on the distributor body (not like the 2nd picture)? If so, that is correct - it should be slightly advanced.
Or does the 3rd picture show the engine is not at TDC - that it is at 5 deg BTDC, and the rotor is as shown in the 2nd picture? If so, then you should make your rotor slightly advanced. I'm not sure, but I think the 3.2 engine went back to a clockwise rotation (correct me if I'm wrong!), in which case you want the rotor pointing slightly to the left of the scribe mark in the distributor body. Your 2nd picture shows the rotor pointing slightly to the right of the scribe mark.
hope this helps!
Kurt beat me to it!
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 05-23-2007, 09:30 AM
I would be interested to hear how others do it, but I center the rotor with the notch on the distributor housing. Is it supposed to be aligned with the edge of the rotor?
Old 05-23-2007, 09:33 AM
johncmng's Avatar
Oh *****, does this mean I set the timing wrong on my cams? Should I reference the TDC to Z1?
Old 05-23-2007, 09:34 AM
johncmng's Avatar
So, in Wayne's book. When he refers to TDC it means Z1 on a 3.2 Carrera? That's the notch on the left of the two notches?
Old 05-23-2007, 09:44 AM
John,
Yes, Z1 is TDC - see here:
Valve Adjusting - Is this TDC?
74er,
This rotor placement is just a guess to get the car started. The real ignition timing is done once the engine is running and using a timing light.
Rex
Old 05-23-2007, 12:25 PM
johncmng's Avatar
Thanks Walter,
Man! I love this forum!!!
Old 05-23-2007, 12:49 PM
Make sure when you put the dizzy in you have the correct TDC in the 720 degree cycle. There is a TDC for number 1 and a TDC for number 4 360 degrees later. You don't want to have the rotor pointing at the groove when the engine is at TDC for number 4.
Walter, the timing is set by the chip on the computer in this car. He has to get the dizzy installed correctly as there is no adjustment on the car.
-Andy
-Andy
Old 05-23-2007, 10:13 PM
Andy,
Thanks for the clarification - I learn something new everytime I get on here.
Rex
Old 05-24-2007, 05:00 AM
johncmng's Avatar
What's a dizzy?
Old 05-24-2007, 08:20 AM
