Relay internal functions
Need to know the internal functions of the common 911 electrical relay(30-85-86-87).Thanks.
Old 05-29-2007, 06:37 AM
Bill Verburg's Avatar
30 is battery positive voltage
87 is a relay actuated contact
86 is the coil control voltage
85 is coil ground
Bill Verburg
Old 05-29-2007, 06:56 AM
Here's typical Bosch DIN relay, 1 make, 1 break type. 87a is typically not included on the round relays; used to break a circuit when the relay is energized. Othewise, the function is the same.
86 is also source voltage. When switched, it energizes the magnetic coil in the relay, then to ground.
Sherwood
Old 05-29-2007, 02:06 PM
