Slumlord
Porsche_monkey's Avatar
No more than an hour.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 06-01-2007, 05:50 PM
Max2.0's Avatar
Well I had kind of figured my 1-2 shift was "just the way a 915 shifts", but I have to go try this out tonight. Max. how long did it take you? Does not sound like a long job if everything is handy.
About 20 Minutes, and half of that was trying to decide whether to do it with the seat pushed all the way forward, or all the way back! ;>))
Actually, I wound up moving the Driver's seat as needed to get to each of the work areas!
1983 911SC... Concours Garage Queen
1987 Carrera M491 Cab... Movin' on out...
1992 968 Coupe Track Car... Gone
1968 911L, '73.5 911T, '75 911S SA, '77 911S Targa, and so forth, thru a '90 S2 Cab...
Old 06-01-2007, 05:56 PM
SCWDP911's Avatar
Did this to my 83 tonight before leaving work. Followed the procedure discussed previously in this thread. Has helped my 1-2 and 3-2 shift a lot. I need to do it one more time though as I am borderline on the 5-4 shift "nicking" reverse now...
Thanks for this info - a BIG help guys...
Shane
- 1984 928S
Old 06-01-2007, 07:25 PM
SCWDP911's Avatar
I was rereading the Bob Tindell writeup and wondered about something that was mentioned from the factory instructions. It said to ensure that there was sufficient shift rod fed into the coupler. Is there any kind of minimum spec on this? The car seems to be shifting a lot better and easier into 2nd now, but I wanted to make sure I did not miss something there...
Shane
- 1984 928S
Old 06-06-2007, 03:32 PM
Tired Member
DaddyGlenn's Avatar
I just tried another shifter improvement. Replacing the ball cup and shift rod bushings--> HUGE difference! I'll do a write up on a new thread.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 08-09-2007, 06:11 AM
Tired Member
DaddyGlenn's Avatar
Here is the link to my shift bushing replacement write up.
http://forums.pelicanparts.com/porsche-911-technical-forum/361157-little-maintenance-big-improvement-shift-linkage-bushings.html#post3418032
Glenn
Old 08-09-2007, 06:41 AM
Horrido's Avatar
Shift Coupler Adjustment
Thank you john walker's workshop for your simple and clear shift coupler adjustment procedure. One more example of the usefulness of the forum search function.
Dan
Old 02-03-2012, 03:12 PM
l_turn9's Avatar
Shifter (Coupler) Adjustment Procedure
Just wanted to remind everyone there's a great Procedure in the WSM. Here's a image showing it - it's on p 578 of the 72-84 Shop manual.
Old 02-15-2020, 09:02 AM
