Cam Timing 3.2 Can someone check my math please?
Good Morning. I am working on cam timing for my 3.2, and discovered that my dial indicator only reads .001" resolution. Specs are in mm. My math is as follows:
1.25mm*.03937= .0492125"
Does this seem correct? Overlap setting at .049"
Thanks!!!
Mackskibum aka Dave Austin
'66 911 Work In Progress (#303734)
'85 911 Carrera
06 325XI
'05 Envoy XL SLT
Old 06-02-2007, 05:16 AM
Somewhere in the Midwest
MotoSook's Avatar
That is the correct conversion.
Old 06-02-2007, 05:28 AM
Thanks Souk!!
'85 911 Carrera
06 325XI
'05 Envoy XL SLT
Old 06-02-2007, 05:31 AM
MotoSook's Avatar
No problem. Good luck with the rest of the work.
Old 06-02-2007, 05:34 AM
Your math is correct but your specs are wrong. Overlap at TDC is set with 0.1 mm valve clearance, not with 1.25 mm.
Cheers,
Joe
Old 06-02-2007, 03:25 PM
I hope I'm not wrong stlrj. I got the specs from Wayne's book as follows:
1984-1989 Carrera 1.1-1.4 (1.25)
The way I read is that 1.1-1.4 overlap is factory spec, 1.25 is ideal.
My math tells me this:
.043-.055 is spec
.049 is ideal.
Your numbers look correct for an SC.
'85 911 Carrera
06 325XI
'05 Envoy XL SLT
Old 06-03-2007, 05:55 AM
You are right. The spec I quoted was for the initial valve clearance.
What you are talking about is the total lift at overlap or TDC and your numbers are correct.
Cheers,
Joe
Old 06-03-2007, 06:08 AM
