Exhausting question - turbo vs. NA
I just had a noobish question about exahausts. Every once in a while I see an exhaust advertised for "turbo 911's or 930's. If the engine was 3.0, but NA instead of turbo, aside from modifying the outlet piping a bit from HX to muffler inlet, to get rid of the turbo section, is there anything in a "turbo" muffler that makes it unusable for an NA car? I know from Miata days, that some engines require properly tuned muff's... in my limited 911 knowledge, I have never read anything that would say that that school of thought applies to 911's.
Sorry to be so windy for a simple question... Can someone set me straight?
Shane - 1984 928S |
Gon fix it with me hammer
NA needs backpressure to run smooth in lower revs
something a turbo get's... from it's turbo anyway don't know if a turbo muffler is different, but a 911 NA generally does require backpressure...without it , rough idle and low torque down low... great at WOT though, so racers don't care about it so much and can run open pipes and whatnot
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Thanks, that helps...
Shane - 1984 928S |
Crotchety Old Bastard
There was a Carrera widebody slant at the Cal Turner show that had a 930 muffler grafted onto a Cat relacement pipe. Pretty slick setup that mocked the turbo look. The muffler should work just fine in any application. It is similar internally to the typical "hotdog" of the early N/A engines.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Would the HX's have a smaller diameter on the turbos, or are they also the same? Brian, did you get my last email yet about the route for the next Fun Run?
Shane - 1984 928S |
