Philbey's Avatar
HELP - Trying to identify an SC Whale Tail
Hi all,
I'm trying to find an authentic era tail for my 1978 SC. I know they changed the tails on them about 81-82, the earlier ones had a different one.
(I think it was 83 that the Turbo look spoiler came in)
I found this one on ebay:
SPOILER
Could anyone verify if this is the era correct spoiler and can anyone pick if its factory or not?
Cheers ,
Tom.
Old 06-21-2007, 04:42 AM
Tom,
That would be correct for your car and it all looks factory. I rather doubt anybody ever made a copy of the rubber tail. You do realize how heavy these tails are, right? If it was my car, I'd look for a fiberglass one.
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 06-21-2007, 05:38 AM
2002M3Drew's Avatar
Send a message via AIM to 2002M3Drew
That is the early 3.0 Carrera Tail, also used on the 1980 Weissach Edition 911 SC. A similar tail was on the early 930. It is characterized by the fact that there is an opening in the top which actually opens down to the grille on the rear decklid. It also looks more like a "tail" than the later ones. The later 930 turbo tails and the Carrera Tail nave a flat top section (there is no exposed opening to the decklid beneath the tail base).
For an SC, that tail could be consider "correct" as it was on the Weissach, and was around chronlogically when the SC was made (it could have ben a dealer installed option.) The turbo tails were also regularly installed on the SC, though they do look kind of large because of the size of the rubber lip. The Carrera tail, obviously, looks the most correct on the SC, as it was designed for the 84-89 Carrera, and the SC body is identical to the Carrera. It can be a chronological faux pax, though, as it came out after the SC was retired. Nevertheless, a delaer could have retrofitted one on to a 1 year old SC in 1984
1983 911SC Coupe
1985 928S
1987 944 Coupe
1992 Carrera C2 Coupe
2006 Cayenne S
Old 06-21-2007, 01:09 PM
2002M3Drew's Avatar
Originally posted by javadog
Tom,
JR
That particular tail in this Ebay ad is far lighter than the Carrera or Turbo tails. There is less of it, because it has a big opening leading down to the deck lid itself.
The sponsor of this site sells (or used to sell) replica rubber lips for the tails, by the way. They are heavy, even the OEM ones.
1983 911SC Coupe
1985 928S
1987 944 Coupe
2006 Cayenne S
Old 06-21-2007, 01:11 PM
Work in Progress
Rich76_911s's Avatar
There are some pictures of the tail that came off of my 1978 911SC in this thread:
For Sale: Early 930/911 Whale Tail
Unfortunetly I just sold the tail.
The rubber for your year should curve upward and not stay flat like the later carrera tails.
Just an FYI boxed up the tail weighed 62 lbs. It costed $110.00 to ship fedex from Pennsylvania to Georgia. I figure by switching to the fiberglass ducktail I added a couple ponies, ha ha ha.
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 06-21-2007, 01:14 PM
"That particular tail in this Ebay ad is far lighter than the Carrera or Turbo tails. There is less of it, because it has a big opening leading down to the deck lid itself."
You are joking, right? That TANK is the heaviest tail ever offered from Porsche. Its all rubber composition mounted on the stock decklid is just plain HEAVY ! We removed plenty over the years to replace with the mostly fiberglass base, metal frame, rubber edged lip units as found on the 75 Carrera and Weissach (which are a lot lighter)
BTW- the all rubber tail option warps quite nicely with exposure to heat and sun
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 06-21-2007, 02:00 PM
Retired Member
Brian 162's Avatar
I had one of those tails on my car before I did a re-paint. I replaced it with a Carrera tail.The old rubber tail weighs a ton.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 06-21-2007, 06:53 PM
I hate to sound anal but, for the benefit of those that search the archives in the future, I have to correct a couple of things. Yes, this tail was available during the production run of the Carrera 3.0 but it was not used on the Weissach edition or the early turbo. Those tails were fiberglass over a metal frame with a rubber edge, in the same basic shape as this one, with the turbo tails having a second grille, in the flat horizontal part. The turbo tails varied a little, in that the early tails had a smaller secondary grille.
To emphasize what TRE said, these all-rubber tails were hugely heavy. Lot's of weight in the absolute worst place for weight on a 911.
The later SC (82, 83) got the 3.3 turbo tail.
JR
Old 06-21-2007, 08:01 PM
Bland
unclebilly's Avatar
That is an early Turbo Tail (76 or 77). I think you want the next whale tail or a carerra tail.
Old 06-21-2007, 09:15 PM
Hmmm. Some of you guys aren't paying attention here. It's not a turbo tail.
Take a look at my last post.
JR
Old 06-22-2007, 04:41 AM
Bill Verburg's Avatar
JR(Javadog) is correct
Some but not all had the secondary grill, which was alternately used for AC or oil cooler
here are the weights of just the tails w/o the lids
MA Shaw C2 spoiler 9#
oem P/U spoiler 20#
83 930 tail 23#
I replaced the p/u tail which was oem on my '76 C3 w/ the Shaw one. The 930 tail info was given to me so no guarantees on accuracy.
The lighter tail does make a noticable difference in the feel of the car in turns and at speed.
by the way if any one needs a lid drilled for the p/u tail let me know i've got one you can have cheap.
Bill Verburg
Old 06-22-2007, 05:26 AM
