Make Bruins Great Again
What do you call this thing and where can I get one?
I need one of these do-hickys. It holds cables in place.
What is it called? Where can I get one?
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
The Love Zone?
'85 911. White - 53,000 miles bought 3-16-07. "Casper" '88 924S. Blue - 120k miles bought with 105k miles. '94 968 Coupe - White - 108,000 miles bought 9-28-17 '09 Cayman - Grey - bought 9-8-20 |
1.367m later
Isn't that the symbol for the artist formerly known as "Prince"?
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
The cruise control cable was secured by that clip. I wouldn't worry too much about it.
Dave
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
I may still have my clip. I'll send it to you if I find it. I removed my non functioning CC.
a bodyshop supply should have something similar.
Found it. Send me your info via PM and I'll sent it to you early next week.
Dave
slodave-thanks. I need one for a wire on my transmission. It matches the one for the cruise cable.
I have been looking for one also.
bumps
Slumlord
You could replace it with a ty-wrap attachment block, then add on the ty-wrap. Not factory, but it would work.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
They are called OMEGA clips for their shape. I have found them through the MBZ dealer in defferent sizes. Not sure if other dealers/parts sources have them.
Paul
If you aint breakin' it, you aint racing it hard enough! 1974 911 3.0 Euro Sahara Beige/Black |
Howard 2003 996tt 1997 911 Coupe Artic Silver (sold) 1988 Black 911 Coupe (gone but not forgetten) |
Thanks guys.
Slumlord
Ask Wayne to stock them.
Ah-ha! I have a mystery hole in my heater vent tube. The CC cable on mine was broken off at the throttle body end of the cable tube. Every time the throttle was opened, the cable sagged down, the tube slipped out of its plastic collar, and the whole thingamajig descended. When the throttle was closed again, the tube would lightly catch slipping back in - only a matter of time until it catches a bit better, leaving the engine at 1/2 throttle at an inconvenient time. I didn't know I was missing the mentioned clip, which would have prevented this failure in the first place. So, I wouldn't drive without it for too long.
On the bright side, a coax cable clamp from home depot (box of 25 for $2.95) does a nice job as a stand - in. Screwed right in place. Careful application of my wife's favorite fix-all (superglue) on the cable tube to collar joint (mine broke off 1/2" inside its plastic collar) got the cruise cable back in shape as well. (My wife, to my amazement, once successfully attached the RH OSRV Mirror on our old beater Alero with superglue. Amazingly, it held for 6 or 8 months!)
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
