How to brighten dash/instrument lights?
Dash/instrument lights can be turned up from almost no illumination to moderately dull illumination. I imagine there is a pretty simple fix to make the switch crank on much higher light intensity but I don't know the answer. Any input appreciated.
EPS
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. - |
Slumlord
Do a search, there was a very long thread here a few months ago.
The simplest fix is to replace all the bulbs with new and make sure you have good ground connections. There are also brighter bulbs and led options, but they are more complicated solutions.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Bland
A very common modification is to put a candle on your steering column and light it after dark. You just need to remember to put it out at gas stations when you fill up.
If you put in scented candles, it can change your whole driving experience...
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
German or US candles?
Will it negate my warranty if I use US candles? German units are very nicely made and function supurbly but after my recent upgrades are considerably out of my price range. I have considered a flashlight however. EPS
Slumlord
Aromatherapy is a side benefit.
OK - had another cup 'O coffee, did a search and now have the answer(s) Thanks for the input. EPS
Shane - 1984 928S |
I just wear a miner's hat with the light in the front. Works great.
Ova Day
For maximum brightitude just light a fa*t.
Works for me, and removes those pesky cobwebs from under the dash.
88 Triple Black 911 Carrera Cab, ex Garage Queen 05 BMW E46 M3 21 Tesla Model 3 LR 08 BMW 328xi 15 Ford F150 |
I replaced all my orig bulbs with new and cleaned all the grounds/sockets and the results were pretty surprising. I will pull the dimmer out of the equation and consider that particular project DONE!
total cost: around $12.
1984 928s 5 speed |
Evil Genius
Does anyone have the part number for the newer 2 watt bulbs? I think you need 10 of them?
I'd like to buy them and have already to install when I pull my gauges.
Life is a big ocean to swim in. Wag more, bark less.
Just about everything related to gauge brightness has been covered in this thread.
Dar - 88 Carrera Coupe "Schotzie" Grand Prix White DIY Upgrades: SW chip, M&K 1in/1out, Bilstein HDs, 17" Turbo Twist 9s&7s, Spring-center clutch, No-Drill Release fork shaft update. |
Evil Genius
I just bought off ebay some premounted white LED's to pop into all 5 gauges in my 911......
For $28 with shipping, it'll be a cheap experiment, and I'll post pictures when installed.
looking for answers
hmmmmm. Interested. Let us know how it works out.
87 Targa, Up for Sale! 77 Wife, stock |
Evil Genius
link to the ebay auction:
And disfin, looking at your sig line, is your wife really a stock 77 model year?
looking for answers
those lights look like a great idea. after you install them let us know on a scale of 1-10 how bright they are, with 5 being the current bulbs and 10 being a modern car.
yep shes a 77. Was a good year.
Do a search here on the board. IIRC, people have experimented with these bulbs in the past and have had very mixed results. I think the chief complaint is that they are very "directional" and don't throw any light from the sides of the bulbs. The result of this is that appear "spotty" and don't provide enough light to clearly light up the gauge. Another issue, IIRC, is that you can't use a dimmer with these bulbs.
1984 Targa Last edited by scottb; 07-10-2007 at 10:10 AM.. |
Slumlord
Dimmer has to go.
I cannot speak from first hand expierience but I believe I read somewhere that if you install relays on your headlights that your instumentation lighting will brighten up a bit.
87 Carrera Cab GP White 01 740i Sport 03 Honda Odyssey |
