e p slick's Avatar
How to brighten dash/instrument lights?
Dash/instrument lights can be turned up from almost no illumination to moderately dull illumination. I imagine there is a pretty simple fix to make the switch crank on much higher light intensity but I don't know the answer. Any input appreciated.
EPS
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 05-24-2007, 04:27 AM
Slumlord
Porsche_monkey's Avatar
Do a search, there was a very long thread here a few months ago.
The simplest fix is to replace all the bulbs with new and make sure you have good ground connections.
There are also brighter bulbs and led options, but they are more complicated solutions.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 05-24-2007, 04:37 AM
Bland
unclebilly's Avatar
A very common modification is to put a candle on your steering column and light it after dark. You just need to remember to put it out at gas stations when you fill up.
If you put in scented candles, it can change your whole driving experience...
Old 05-24-2007, 04:42 AM
e p slick's Avatar
German or US candles?
Will it negate my warranty if I use US candles? German units are very nicely made and function supurbly but after my recent upgrades are considerably out of my price range. I have considered a flashlight however. EPS
Old 05-24-2007, 05:03 AM
Slumlord
Aromatherapy is a side benefit.
84 Cab - sold!
Old 05-24-2007, 05:08 AM
e p slick's Avatar
OK - had another cup 'O coffee, did a search and now have the answer(s) Thanks for the input. EPS
SCWDP911's Avatar
That is the funniest thing I have read or heard all day!
Shane
- 1984 928S
Old 05-24-2007, 05:15 AM
I just wear a miner's hat with the light in the front. Works great.
Old 05-24-2007, 06:42 AM
Ova Day
msterling's Avatar
For maximum brightitude just light a fa*t.
Works for me, and removes those pesky cobwebs from under the dash.
88 Triple Black 911 Carrera Cab, ex Garage Queen
05 BMW E46 M3
21 Tesla Model 3 LR
08 BMW 328xi
15 Ford F150
Old 05-24-2007, 06:50 AM
I replaced all my orig bulbs with new and cleaned all the grounds/sockets and the results were pretty surprising. I will pull the dimmer out of the equation and consider that particular project DONE!
total cost: around $12.
1984 928s
5 speed
Old 05-24-2007, 07:54 AM
Evil Genius
Rusty Heap's Avatar
Does anyone have the part number for the newer 2 watt bulbs? I think you need 10 of them?
I'd like to buy them and have already to install when I pull my gauges.
Life is a big ocean to swim in.
Wag more, bark less.
Old 05-24-2007, 08:11 AM
Neuromancer's Avatar
Just about everything related to gauge brightness has been covered in this thread.
Dar - 88 Carrera Coupe "Schotzie" Grand Prix White
DIY Upgrades: SW chip, M&K 1in/1out, Bilstein HDs, 17" Turbo Twist 9s&7s,
Spring-center clutch, No-Drill Release fork shaft update.
Old 05-24-2007, 09:21 AM
Evil Genius
Rusty Heap's Avatar
I just bought off ebay some premounted white LED's to pop into all 5 gauges in my 911......
For $28 with shipping, it'll be a cheap experiment, and I'll post pictures when installed.
Old 07-09-2007, 03:17 PM
looking for answers
disfin's Avatar
hmmmmm. Interested. Let us know how it works out.
87 Targa, Up for Sale!
77 Wife, stock
Old 07-09-2007, 05:18 PM
Evil Genius
Rusty Heap's Avatar
link to the ebay auction:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=140134612175&ssPageName=ADME:B:BCB:MT:12
And disfin, looking at your sig line, is your wife really a stock 77 model year?
Old 07-10-2007, 05:54 AM
looking for answers
disfin's Avatar
those lights look like a great idea. after you install them let us know on a scale of 1-10 how bright they are, with 5 being the current bulbs and 10 being a modern car.
yep shes a 77. Was a good year.
77 Wife, stock
Old 07-10-2007, 07:29 AM
scottb's Avatar
Do a search here on the board. IIRC, people have experimented with these bulbs in the past and have had very mixed results. I think the chief complaint is that they are very "directional" and don't throw any light from the sides of the bulbs. The result of this is that appear "spotty" and don't provide enough light to clearly light up the gauge. Another issue, IIRC, is that you can't use a dimmer with these bulbs.
1984 Targa
Old 07-10-2007, 09:05 AM
Slumlord
Dimmer has to go.
84 Cab - sold!
Old 07-10-2007, 09:12 AM
I cannot speak from first hand expierience but I believe I read somewhere that if you install relays on your headlights that your instumentation lighting will brighten up a bit.
87 Carrera Cab GP White
01 740i Sport
03 Honda Odyssey
Old 07-11-2007, 11:24 AM
