Scott R's Avatar
Low idle when I push the brakes
I have a brand new engine, 3.0l 9.9.2 compression, and 964 cams. With the new cams, whenever I hit the brakes my MAP goes down, and the idle lowers. Anyone have to install a vacuum canister after they changed cams, and how did you do it? Or what did you do to get around this?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-23-2007, 09:28 AM
Bill Verburg's Avatar
There should be an L shaped check valve where the vac line ties into the vac can. Make sure that is functioning.
Bill Verburg
Old 07-23-2007, 10:07 AM
Scott R's Avatar
Where is the vac can? I know where the brake booster line is, and where it goes into the firewall.....
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-23-2007, 05:17 PM
