Low idle when I push the brakes
I have a brand new engine, 3.0l 9.9.2 compression, and 964 cams. With the new cams, whenever I hit the brakes my MAP goes down, and the idle lowers. Anyone have to install a vacuum canister after they changed cams, and how did you do it? Or what did you do to get around this?
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
There should be an L shaped check valve where the vac line ties into the vac can. Make sure that is functioning.
